Jun 9, 2009 - 2:22 AM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
My celi recently started squeeking like a old mattress when in gear (more pronounced in 1st gear, probably due to cruising at lower speeds.) It goes away after the car has warmed up. It happens even if I put the car in 1st gear and do not release the clutch (effectively neutral-1st). Any ideas?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." ![]() |
Jun 9, 2009 - 3:51 AM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
My celi recently started squeeking like a old mattress when in gear (more pronounced in 1st gear, probably due to cruising at lower speeds.) It goes away after the car has warmed up. It happens even if I put the car in 1st gear and do not release the clutch (effectively neutral-1st). Any ideas? is it a squeek or more of a high pitch gear whine? start it up cold and imediately put it in gear and just cruise at 20-30k, turn the wheel sharp to the left and right 3-4 times. What Happens??? |
Jun 9, 2009 - 9:12 AM
My celi recently started squeeking like a old mattress when in gear (more pronounced in 1st gear, probably due to cruising at lower speeds.) It goes away after the car has warmed up. It happens even if I put the car in 1st gear and do not release the clutch (effectively neutral-1st). Any ideas? is it a squeek or more of a high pitch gear whine? start it up cold and imediately put it in gear and just cruise at 20-30k, turn the wheel sharp to the left and right 3-4 times. What Happens??? Definitely a squeek, like a rusty old fence kind of squeek. Tight turning makes no effect on the sound. -------------------- Fred
Jun 11, 2009 - 11:37 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
it squeaks in first while the clutch is depressed. and also when its released...
release bearing possibly? just a guess. these kinds of things are tough to diagnose w/o being there -------------------- ![]() |
Jun 12, 2009 - 4:43 AM
Enthusiast ![]() ![]() ![]() Joined May 10, '07 From Lubbock, Texas Currently Offline Reputation: 2 (100%) |
wheel hub man check the wheel hub.........jack the front of the car up lock the steeringwheel and start with driver side try to move the wheel side to side up and down then the pass side do the same.....if either side moves or has any slack to it ur berrings r bad they should not move AT ALL
-------------------- ![]() feedback feedback If I buy or sale please leave me feedback...thanks cheap, quick, reliable, pick two I treat my 6gc better then my own woman |
Jun 12, 2009 - 6:00 PM
mine does this as well, in gear and at idle. Turned out to be powersteering pump -> when you first start up the vehicle no fluid gets to it so it makes a squeel/squeek as the belt starts to get the pump working. For me it was also like an annoying buzz.
| Lo-Fi Version | Time is now: August 29th, 2026 - 9:48 PM |
