Jun 9, 2009 - 12:18 PM
Enthusiast ![]() Joined Nov 13, '08 From Indiana Currently Offline Reputation: 0 (0%) |
so i was reading the sticky's on the 5sfte. and it said something about the two different models of ct26 turbos not being interchangeable with the 3s manifolds....so i was wondering aftermarket wise...if i was wanting to go bigger turbo wise what would fit to the 3s turbo manifold?
This post has been edited by silverceli09: Jun 9, 2009 - 12:19 PM -------------------- Celica Or Die, check out http://www.redlinemotive.com!
Jun 9, 2009 - 3:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
only a ct series turbo will bolt directly onto the 3sgte turbo manifold. The only ct that won't bolt onto the manifold is the single entry ct-26 found in the 1st gen 3sgte and supras. Either get a ct20b or a ct27 from ats and call it a day.
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Jun 10, 2009 - 1:16 AM
Enthusiast ![]() ![]() ![]() Joined Feb 2, '06 Currently Offline Reputation: 3 (100%) |
get an adapter to fit a bigger turbo eg. T3/T4, T3 flange turbos
i got a custom-made adapter from CT26 to suit T2(25, 28) flange turbos. im fitting a GT2871 and also using gen2 3sgte manifold. also will need to buy 3sgte downpipe and get a flange welded on to suit outlet of turbo, in my case, i got a 5bolt T25 style outlet welded on a 3sgte downpipe. i plan on keeping the dump pipe open!!! This post has been edited by NGHTKD: Jun 10, 2009 - 1:18 AM |
Jun 10, 2009 - 2:11 AM
cal, i see you got plans.
Jun 10, 2009 - 5:21 AM
Jun 10, 2009 - 6:20 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
when do you plan on sharing these plans on ozcelica cal??
-------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
Jun 11, 2009 - 3:09 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
May I ask you guys.. Can an external wastegate port be added to a 3s-gte manifold aswell as the adaptation to the Garrett T2871 (or similar) turbo without running into space issues (eg proximity to radiator fans, etc) while using the stock w2a intercooler?
-------------------- Mike W
Jun 11, 2009 - 5:08 AM
| Lo-Fi Version | Time is now: July 29th, 2026 - 9:03 AM |
