Jun 12, 2009 - 11:40 PM
Enthusiast ![]() ![]() Joined Feb 2, '09 From new orleans La. Currently Offline Reputation: 5 (86%) |
I have my ct20 installed and I read on a install/removal prosess it says to keep the banjo bolt on the engine lose when installing the feed line an crank the car till oil comes out to build pressure in to the system for oiling the turbo the when you see oil tighten it up. They called it priming the oil feed line. I myself did not do this an I am not sur eif I am getting oil to my turbo. Is this the right to do it does it have to be primed?
This post has been edited by mk7celica: Jun 13, 2009 - 4:36 PM |
mk7celica Oil to turbo need to be primed? And may need rebuild Jun 12, 2009 - 11:40 PM
Smaay just unplug the ECU fuse and crank the engine over... Jun 13, 2009 - 9:08 AM
mk7celica Well I think I found metal flakes in my oil. Its c... Jun 13, 2009 - 4:42 PM
lagos QUOTE (mk7celica @ Jun 13, 2009 - 5... Jun 13, 2009 - 6:28 PM
mk7celica He lives 4 hours away an he cant get over here til... Jun 13, 2009 - 8:25 PM
Smaay change the oil and see if its still in there Jun 14, 2009 - 11:31 PM
mk7celica So Today I pulled the turbo again I had to check... Jun 17, 2009 - 10:56 PM
_Jim_ Great to hear you finally got it all sorted out, i... Jun 18, 2009 - 5:51 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 4th, 2026 - 12:20 PM |
