Jun 22, 2009 - 9:50 AM
Enthusiast ![]() ![]() Joined Jan 12, '09 From State College, PA Currently Offline Reputation: 1 (100%) |
So I did something pretty careless when I did all 4 brakes about 6 months ago... I lost the little pins that go in the front to separate the pads from the rotors. I know... you don't need to tell me I'm a moron lol. I haven't seen any problems in either braking or excessive brake wear but when I turn the car I can hear the pads up against the rotor for a few seconds and after coming to a stop they scrape for a few seconds. (It just briefly sounds like a faulty Catalytic converter). So........ can I find replacements for this at a local shop or online or should I look to get them from another member who's parting out? Could I make them? lol Whats my best option?
Jun 23, 2009 - 10:43 AM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
What exactly do you mean by "pins"?
There are shims and spring clips. No pins that I've ever seen. At least I hope you don't mean the big slide pins/bolts that the caliper slides on Edit: if you mean the V-shaped spring wires, those are NOT to separate anything. Those are anti-squeal devices and yes, they are available from your Toyota dealer for about $20 a set IIRC. If your pads are dragging on the rotor, check to make sure the caliper slides easily and the pads are installed properly. Also use brake grease at all sliding points. This post has been edited by dgbldr: Jun 23, 2009 - 10:53 AM |
Jun 23, 2009 - 1:05 PM
Yes that's what I mean and thank you for clarifying on what I meant lol.
The spring wires that push your pads back into place after braking. That's the only thing I think it could be since I lost them when changing my brakes but I'm due for new pads so I'll check everything over when I do that. Thanks |
Jul 2, 2009 - 9:48 PM
yes most part stores carry them. I use to replace them every time I did my brakes. They also come in caliber repair kits.
edit I forgot to tell you, They won't be car specific. They will be universal fit so you might have to bend them a bit or cut the ends off some. you can also make your own if you head over to a hardware store.. if you need any help just drop me a message. This post has been edited by macavely: Jul 2, 2009 - 9:50 PM -------------------- |
| Lo-Fi Version | Time is now: May 18th, 2026 - 12:22 AM |
