> TPS 80% at WOT? Timing at 5 degrees at idle?
post Jun 29, 2009 - 9:15 PM
Agent21
Joined Sep 12, '05
From Who says you can't circle race a celica?
Trying to figure out what the in the hell is up here. Got a snap on mt2500 so I can read live data from the motor. Idle is around 5 degrees advance at temperature. Also noting Wide open throttle maxes out at 80% reading from the TPS. Also lean code from engine. Looks like I need to advance the timing by 5 degress and move the tps?
94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief
Lo-Fi Version Time is now: August 31st, 2026 - 9:35 AM
