> Resonator?, To Remove or Not To Remove?
post Jul 9, 2009 - 12:21 AM
RavenAegis45
Joined Jun 25, '08
From CA
OK I'm just wondering if removing the Resonator on my Intake would yield any noticeable performance gains on my car? Or help with my MPG?
The Resonator on the 5S-FE Intake is on the Underside of the Intake Tube is it? or is it someplace else?
This post has been edited by RavenAegis45: Jul 9, 2009 - 12:26 AM
post Jul 9, 2009 - 12:57 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
I doubt it will do anything, I think all it is for is sound deadening.
post Jul 9, 2009 - 2:02 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
its safe to delete that, you can cap off the end any way you like, you'll get a little extra intake roar but no extra power.
for best results use a 3" aluminum intake pipe with 2.5-3" reducer couplers, either get an intake pipe with the correct nipple for that oil breather hose otherwise chuck a mini air filter on the end of the valve cover.
Mike W
269awhp / 273ft-lbs
post Jul 9, 2009 - 2:48 AM
Projek_01
Joined Feb 18, '07
From Calgary, Alberta
i picked up a white plastic cap for ABS tubing from the homedepot for 60cents and it does the job. its really thick plastic so it can handle the stress of the clamp. there is also another resonator in the lid of the air filter box.
Lo-Fi Version Time is now: July 8th, 2026 - 4:35 PM
