> fog light question
post Jul 17, 2009 - 1:01 PM
NewOrleans
Joined Jan 27, '09
From New Orleans
i have been wanting to get the fog lights for my ST but was wondering what would need to be done to have em wired up correctly and everytign
post Jul 18, 2009 - 3:09 PM
NewOrleans
Joined Jan 27, '09
From New Orleans
anybody???
This post has been edited by NewOrleans: Jul 18, 2009 - 3:09 PM
post Jul 20, 2009 - 1:10 AM
zonz540
Joined Jul 3, '09
From UT
mine already has the wires zip-tied inside, next to the radiator on both sides. It has never had fogs. Check yours.
post Jul 20, 2009 - 7:08 AM
ksporry
Joined Mar 14, '09
From Portishead
In Europe teh standard models should already have fog lights fitted. I ran into this issue because a garage told me my model failed the MOT (roadworthiness test) due to absence of a fog light. However, he conned me because a car that does not have a fog light and does not have fog light controls, does not require a fog light, but if it has either the light or the controls, it should have the whole installation and it should be working properly.
This guy said I had fog lights but no control. Turns out that he just wanted to make a few pennies extra (because aswitch and wire costs next to nothing). He wired the one of the second brake lights as fog light, which screwed up the light-out indication circuit. So I fixed that but then was left without fog light. So I wired in a new fog light, which is quite easy to do:
Get a fog light from some car accessory shop and mount it to the rear bumper (check your country's regulations on location of the fog light. In the UK that's between 30 and 50 cm above ground level and either right or at centre of the rear bumper).
Run a wire to a switch in teh front (you need only one wire, the other you can connect to chassis directly from the lamp). Wire the switch to the high beam light (I think, because it will actually switch the fog light off when using high beam) via a fuse and you should be good to go. You can double check using the wiring schematics elsewhere on this site...
post Jul 22, 2009 - 12:00 AM
NewOrleans
Joined Jan 27, '09
From New Orleans
QUOTE (zonz540 @ Jul 20, 2009 - 2:10 AM) *
Could you get some pics or a betterdescription because I looked and didn't see anything
post Jul 22, 2009 - 12:09 AM
zonz540
Joined Jul 3, '09
From UT
Yeah, ill see what i can do.. Im getting some brackets from asdbeard. Ill take pics when i get them and hook them up.
post Jul 23, 2009 - 4:30 PM
NewOrleans
Joined Jan 27, '09
From New Orleans
ok
This post has been edited by NewOrleans: Jul 23, 2009 - 4:30 PM
post Jul 23, 2009 - 9:29 PM
trdproven
Joined Aug 2, '05
From Guam
There were fogs for USDM 96-99 celicas so the factory harness or switch may possibly be already in place, you'll have to check. Now for the 94-95 USDM ones never came with fogs, you would have to wire it up manually. Either way if you don't find wiring for both you would have to do it yourself.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 23, 2009 - 10:31 PM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
I actually have to wire fogs up soon. I see the connectors for them under the hood, but where is the other end of those wires? There is no fog light switch in my car.
post Jul 24, 2009 - 11:10 AM
trdproven
Joined Aug 2, '05
From Guam
It might be like the integras where the other end of the harness is near the pedals and you still need the switch and relay. Look for those things first.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 24, 2009 - 5:43 PM
NewOrleans
Joined Jan 27, '09
From New Orleans
well what im going to end up doing is running the power of fog lights off of one of the windows.
so that it will only get power when the car is on.
and then i will put a switch inbetween power from windows to lights so i can turn them on and off as i please
what do you think about that?
post Jul 24, 2009 - 11:13 PM
Ruroniarc
Joined Mar 19, '09
From Malden, MA
You will blow a fuse. Definitely. There are plenty of spots on the fusebox for options you don't have (unless your celica is fullllllllly loaded) Just pull a new circuit.
Lo-Fi Version Time is now: June 28th, 2026 - 7:58 AM
