Jul 17, 2009 - 4:20 PM
Enthusiast ![]() ![]() ![]() Joined Feb 6, '08 From Oregon Currently Offline Reputation: 8 (100%) |
So i left work today and was cruising down the highway only doing about 63 and my airbag light came on. I freaked out, immediately put my hands to the bottom of the wheel and sat way back, just in case it went off randomly.
Anybody ever have this problem? Should i be worried about my airbag randomly going off? I turned my car on and off several times and it still stays on... help -------------------- 1 JL 1,000/1v2
2 JL 12" W6v2 2 Focal 6.5 component 165a1 Kenwood DDX512 head unit Running 142.6db with the back seat up:) |
Jul 17, 2009 - 5:32 PM
Enthusiast ![]() Joined May 14, '08 From Cape Coral, FL Currently Offline Reputation: 0 (0%) |
mine does the sam thing too... its happened just wit hthe past week to two weeks
Jul 17, 2009 - 6:04 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
get a diagnostics check at an auto electrician there might be a fualt somewhere, they can turn the light off for you.
Jul 17, 2009 - 6:05 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
Could be a loose wiring.
Jul 17, 2009 - 9:22 PM
if the light is on then the SRS system is not working and not going to work if you are in an accident.
do a search for SRS or airbag, there's a couple of posts that show you how to check the codes and clear them (if there are no problems). -------------------- |
| Lo-Fi Version | Time is now: June 16th, 2026 - 11:39 PM |
