4 Pages V  « < 2 3 4
> Installed Ebay header
post Feb 11, 2010 - 12:37 AM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (johnnehh @ Feb 10, 2010 - 9:31 PM) *
QUOTE (benzo @ Feb 10, 2010 - 9:13 PM) *
QUOTE (trdproven @ Feb 10, 2010 - 7:58 PM) *
headers makes your 3rd gear stretch, better top end. but after the headers I did get an EGR CEL code. Must be dealing with the way the whole headers thing works with the engine now. More carbon?
Ive had mine for a month now.. put on a good 2000 miles on it. no CEL code yet..
how long did it take before yours came on?
Took mine about 15 seconds.
you 2 have gt's, i have an st. could that be it?
or maybe cause mine is obdI since its a 95?
post Feb 11, 2010 - 2:59 AM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (benzo @ Feb 11, 2010 - 11:13 AM) *
couple days after but it goes on and off here and there.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 11, 2010 - 3:03 AM
SoDo
Joined Dec 16, '07
From Chicago, IL
Havent thrown a cel yet. I couldnt get the second o2 sensor from the exhaust manifold out. I just plugged in the first one. Gotta get the second one out of the manifold one of these days.
1999 Celica GT Hatchback
post Feb 11, 2010 - 7:37 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i never installed the second factory O2 sensor in mine. what you see in the picture is actually a wodeband O2 sensor. i never got a CEL.
as for the EGR coding. check the vacume lines on the EGR. one of mine kept blowing off, i had to zip tie it on.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Feb 12, 2010 - 1:33 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Still running with upstream O2 sensor only...still no CEL. I got the downstream one in a box, but still see no need to install till I pop codes.
post Feb 12, 2010 - 3:13 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
You wont throw a code for the downstream O2 (Post cat.) because its used for checking emissions not controlling, their for it doesn't effect your air to fuel. Which means no light.
post Feb 12, 2010 - 4:23 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (hatchy_gt-s @ Feb 12, 2010 - 4:13 PM) *
Good to know...how exactly is the down stream sensor used for checking emissions?
post Feb 12, 2010 - 4:38 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
well ****.. i spent hella time making an extension with the o2 sensor. I wish i knew i didnt need it.
since i DO have it tho.. does that mean I can pass smog with my headers? In cali.
post Feb 12, 2010 - 8:05 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (Spider77 @ Feb 12, 2010 - 9:23 PM) *
It reads the gases moving threw the exhaust after the cat. and see what gases are leaving the tail pipe ie hydrogen, oxygen, carbon, exe. and then stores that info in the ECU, and for people who know what Im talking about, it is also used for short and long term fuel trims.
post Feb 12, 2010 - 8:10 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (benzo @ Feb 12, 2010 - 9:38 PM) *
It depends on the state regulations(not familiar with cali), also many of our cars come with 2 cat.s (1 header and 1 after the down pipe) and if you have the 2 cat system then yes you will pass.
P.S. I thought cali was a no mod. state?
post Feb 12, 2010 - 8:15 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (hatchy_gt-s @ Feb 12, 2010 - 8:05 PM) *
So that pretty much applies for OBDII then. I got OBDI and dont see any way of anyone pulling info off my ECU.
post Feb 13, 2010 - 12:14 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you will never pass smog in CA with this header. its not CARB legal, but its a 30 minute job, just switch back when you need to.
post Feb 13, 2010 - 9:26 AM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (Smaay @ Feb 13, 2010 - 12:14 AM) *
good thing i saved the old stock header.
4 Pages V  « < 2 3 4
Lo-Fi Version Time is now: May 27th, 2026 - 10:58 PM
