> squeaky shifting
post Jul 31, 2009 - 12:06 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
So I've noticed that when I am shifting from 1st to 2nd, 3rd to 4th, or down shifting from 5th to 4th it sounds like my shifter cables are squeaking. It doesn't do it from 2nd to 3rd, or 4th to 5th, so it has something to do with the physical motion of shifting "down".
No noise from depressing the clutch, nothing from the pedal. It is just two squeaks while moving the shifter down (eg: 1st to neutral, neutral to 2nd).
Thoughts?
**** Photobucket
post Jul 31, 2009 - 11:51 PM
enderswift
Joined Jul 12, '08
i just sprayed WD on the linkages under the hood. solved my issue and has lasted since june 08. just dont make a mess, less is more in this situation.
Lo-Fi Version Time is now: July 8th, 2026 - 4:37 PM
