Aug 5, 2009 - 8:33 PM
Enthusiast ![]() ![]() ![]() Joined Jan 20, '08 From East Coast Currently Offline Reputation: 1 (100%) |
Quick question...will 7th gen front seats bolt directly into a 6th gen?
Aug 5, 2009 - 8:39 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
Quick question...will 7th gen front seats bolt directly into a 6th gen? direct bolt on NO but they can be made to fit. -------------------- ![]() |
Aug 5, 2009 - 9:02 PM
Aug 5, 2009 - 9:04 PM
Quick question...will 7th gen front seats bolt directly into a 6th gen? direct bolt on NO but they can be made to fit. How? Are there universal guides or something? no, but we have a search bottom that can help you find a post with a step by step on how to install them -------------------- ![]() |
Aug 6, 2009 - 8:55 AM
Enthusiast ![]() ![]() ![]() Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
or if your anywhere near me i v
can put the whole thing in front and rear for 175 |
Aug 7, 2009 - 10:15 AM
Aug 7, 2009 - 2:27 PM
Enthusiast ![]() ![]() Joined Aug 29, '08 From AZ, US Currently Offline Reputation: 21 (100%) |
http://www.celica-club.co.uk/wiki/index.ph..._seats_in_Gen_6
or if your anywhere near me i v can put the whole thing in front and rear for 175 I only have the fronts but I can manage myself if I know what needs to be done. Thanks anyway though. |
Aug 7, 2009 - 4:59 PM
Enthusiast ![]() ![]() ![]() Joined Nov 20, '04 From Carlisle, PA Currently Offline Reputation: 27 (100%) |
Not sure why you'd want to do any welding on them...doesn't sound very safe. I put them in my Celica- all you have to do is take the bottom metal support piece off of the 6th gen seat cushion and swap it onto the 7th gen seat (you have to completely disassemble them to do that, but its not hard at all)....no welding required and perfect fitment.
Aug 7, 2009 - 6:04 PM
Not sure why you'd want to do any welding on them...doesn't sound very safe. I put them in my Celica- all you have to do is take the bottom metal support piece off of the 6th gen seat cushion and swap it onto the 7th gen seat (you have to completely disassemble them to do that, but its not hard at all)....no welding required and perfect fitment. welding is welding....your brackets are spot welded your car is spot welded....not a matter of safe jus if its done right |
Aug 7, 2009 - 8:03 PM
Thanks for the info guys but I think I'm just going to follow AMCMoe's way of switching the supports out.
Aug 8, 2009 - 4:48 PM
any tips or picts to illustrate your point?? i've got both seats.. i've tried removing the slider.. but the i cant seem to dissemble the seats.. i need pointers.. i cant find the bolt/screw to remove the top part of the seat which connects to the frame.. the bottom part was easy.. just 4bolts and the seats comes off..
Not sure why you'd want to do any welding on them...doesn't sound very safe. I put them in my Celica- all you have to do is take the bottom metal support piece off of the 6th gen seat cushion and swap it onto the 7th gen seat (you have to completely disassemble them to do that, but its not hard at all)....no welding required and perfect fitment. |
Aug 8, 2009 - 11:03 PM
Did you take the plastic pieces off the side of the rails? You'll need to take them off....there are bolts hidden behind them.
![]() If I get some time tomorrow, I'll take my passenger seat out and take some pictures of them. |
Aug 12, 2009 - 5:51 PM
Quick question...I heard that I can order (from Toyota) the inner door leather inserts (where mine now has cloth). Is that true?
Aug 12, 2009 - 9:31 PM
I don't see them in the parts catalog. They're glued to the door panel aren't they? I've looked for replacement leather inserts without any luck so I repainted mine and they came out Great. What color leather are you looking for? Black? I have some spare door panels with tan leather if you're interested in them.
I was asked in a PM how to remove the plastic pieces from the seats....so I took some pictures of them to show where the 'tabs' are that mount to the rails. Those plastic trim pieces are quite strong, so don't worry too much about breaking them...they're flexible. Just use a flathead screwdriver and they'll pry off. ![]() By the way, thats the handle that flips the seat forward and height adjustment knob you see on the panel....you'll need to pry the plastic up on the inside of the handle to get it off the metal tab holding it on. This post has been edited by AMCMoe: Aug 12, 2009 - 9:36 PM |
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:38 PM |
