21 Pages V  « < 7 8 9 10 11 > »
> johnnehh's Progression, 1996 Celica GT
post Oct 13, 2009 - 9:28 PM
richee3
Joined Jun 29, '08
From Denver
Gauges on your A-Pillar look like s*** anyway, regardless of the fit. I'd save up and get Dustin's gauge pod, then do suspension.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Oct 13, 2009 - 9:35 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (richee3 @ Oct 13, 2009 - 10:28 PM) *
Ripping off the useless gauge pod on friday, then saving for lowering springs wink.gif
Then comes Dustin's pod. In that order.
1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver
post Oct 13, 2009 - 9:37 PM
Dude, I'd just forget about the gauges...honestly, it's ricey. You don't need them.
Save up your money for things that make sense, like the lowering springs you mentioned, and don't forget replacement shocks that go with those.
This post has been edited by SwissFerdi: Oct 13, 2009 - 9:38 PM
post Oct 13, 2009 - 9:39 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (SwissFerdi @ Oct 13, 2009 - 10:37 PM) *
How long can I go without getting new shocks? (When I install the lowering springs)
post Oct 13, 2009 - 9:46 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (johnnehh @ Oct 13, 2009 - 10:39 PM) *
First of all, that's a good order to get things in. (Refer to your earlier post about suspension and the gauge pod.) Second, your factory struts will last maybe a month on lowering springs. Don't waste your time with putting new springs on, then have to take everything back off to put new struts in later. Just save up and do it all at once. Take it from me.. I've had to redo my suspension 3 times now, because of lowering springs on factory struts, and it gets old, taking everything apart.
1998 Celica GT-
BEAMS Swapped.
post Oct 13, 2009 - 9:48 PM
Speaking of, how hard is it to install the springs yourself? I always thought a compression machine was necessary.
post Oct 13, 2009 - 9:56 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (SwissFerdi @ Oct 13, 2009 - 9:48 PM) *
Nope. Depends on how good you are. I thought it was necessary too, so I rented it, but I didn't need it at all when I did mine. The OEM springs are taller than the springs, if you think about it. Since KYB's are OEM replacements, they should be too (But I cannot confirm that.) Just be careful that you don't push the strut down, or it's a pain to pull back out. But putting lowering springs on your car is an easy DIY job. Pm me if you want a more detailed explanation. No need to clutter jonnehh's thread. Jonnehh, same to you, if you buy lowering springs. I'd be glad to tell you how to install them. It's not hard at all.
This post has been edited by richee3: Oct 13, 2009 - 9:56 PM
1998 Celica GT-
BEAMS Swapped.
post Oct 13, 2009 - 9:57 PM
Last post on this subject, I'll PM you when I buy the supplies...which will be a little while. But if I can save a few hundred doing it myself...I'm willing to go for it.
post Oct 13, 2009 - 10:15 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Are you able to catch a video (safely) showing the boost gauge and the tachometer as you're driving? from a standstill and catch both part throttle and full throttle?
Curious to see on NA.
Mike W
269awhp / 273ft-lbs
post Oct 13, 2009 - 10:33 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (delusionz @ Oct 13, 2009 - 10:15 PM) *
I'll do it when this typhoon is over. Haha. Actually, I might go do it right now. tongue.gif
Just gotta be a bit safer than usual.
post Oct 13, 2009 - 10:42 PM
delusionz
Joined Feb 11, '08
My gauge springs right up to 0 with a bit of throttle. At 2000 rpm it springs up to about 3psi (or 4psi if I floor it)
Mike W
269awhp / 273ft-lbs
post Oct 13, 2009 - 10:53 PM
Rusty
Joined Nov 5, '07
From New Zealand
dont know if its been said, but you have a warning light on.
post Oct 13, 2009 - 11:09 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (Rusty @ Oct 13, 2009 - 11:53 PM) *
It's from the header. The cat is gone.
post Oct 13, 2009 - 11:32 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (delusionz @ Oct 13, 2009 - 11:15 PM) *
http://www.youtube.com/watch?v=uCWcxhjXrzI
All those bright lights will be gone soon. I'm taking off all the rice stuff and doing things right. smile.gif
This post has been edited by johnnehh: Oct 13, 2009 - 11:43 PM
post Oct 13, 2009 - 11:42 PM
delusionz
Joined Feb 11, '08
Wow interesting, so It never actually gets to 0?
And the OEM tachometer is a bit too generous?
Mike W
269awhp / 273ft-lbs
post Oct 13, 2009 - 11:46 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (delusionz @ Oct 14, 2009 - 12:42 AM) *
It's a cheap ricey piece of crap toy. I hate it. I'm going to burn it.
And it's about right. The video delays a little bit and makes it look off... I should have kept it at 3,000 rpm, it just looks off because of the video.
post Oct 13, 2009 - 11:50 PM
CelicaST_CALI
Joined Feb 28, '07
The boost gauge is hooked up?to wat?a Echarger?laugh.gif yea this typhoon is kicking my celicas ass
BANNED. for life, you moron.
post Oct 13, 2009 - 11:51 PM
johnnehh
Joined Aug 5, '09
From Oakley, CA
QUOTE (CelicaST_CALI @ Oct 14, 2009 - 12:50 AM) *
Vacuum... Like what it's designed for. It would actually be a helpful little tool if it read accurate readings. kindasad.gif
post Oct 13, 2009 - 11:56 PM
delusionz
Joined Feb 11, '08
Nah the boost gauge is fine, just keep it. You've probably put screw holes in your pillar anyways.
It all looks fine to me, a little on the cheap side yeah, but still in proportion to the value / spec of the car at the moment.
Now that kinda stuff would not be acceptable on my GT4 lol, I have an HKS gauge, and interested in getting AEM AFR gauge from the US.
Mike W
269awhp / 273ft-lbs
post Oct 14, 2009 - 1:34 AM
2celicas2love
Joined Oct 4, '09
From Pomona, CA
i love the progress and love the car all around reminds me so much of my first celica '94 st in black. I believe this car looks best in black and your interior is so flawless love it!
The heart has its reasons which reason knows nothing of
2000 7th gen GTS 6spd
95 st, swapped 3sgte 3rd gen wrc version :D
Lo-Fi Version Time is now: September 2nd, 2025 - 2:47 AM
