> Bad fuel? --Fixed!, it was something else
post Aug 13, 2009 - 4:01 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
drove the car round trip for 40mi this morning, no problem
Got in this afternoon, and had a slight sputtering? problem that has gotten worse and worse.
ON throttle, i have really no power, the car sounds like its really straining, and the smell out the exhaust is very high in gasoline. Once i get it up to higher speeds (65+mph) it kinda goes away but its still there.
I checked the plugs and wires, all is good.
just bad gas?
This post has been edited by samir0189: Aug 21, 2009 - 4:00 PM
My F/S Thread!
Ferdi says (11:29)
- samir0189   Bad fuel? --Fixed!   Aug 13, 2009 - 4:01 PM
- - Bitter   sounds like a misfire rooted in the ignition syste...   Aug 13, 2009 - 6:55 PM
- - samir0189   I agree that is sounds like, and feels like a misf...   Aug 14, 2009 - 12:28 PM
- - Bitter   hows the cap and rotor? does the coil ohm out to ...   Aug 14, 2009 - 7:34 PM
- - samir0189   Don't really know how to check all that Bitter...   Aug 14, 2009 - 8:48 PM
- - Bitter   grab a cheap ohm meter, i know the specs are avail...   Aug 14, 2009 - 9:54 PM
- - samir0189   i wiggled the wires, nothing noticeable. ALthoug...   Aug 14, 2009 - 10:10 PM
- - Bitter   bosch platinum spark plugs by any chance are whats...   Aug 15, 2009 - 8:54 AM
- - samir0189   Yes, please dont remind me. Lol. Ive heard it tooo...   Aug 15, 2009 - 8:58 AM
- - Bitter   you should have stated that in the first post. cha...   Aug 15, 2009 - 10:50 AM
- - samir0189   Some new NGK 7092 platinum tip plugs in there, no ...   Aug 15, 2009 - 1:06 PM
- - samir0189   I just took it for a run, the new plugs helped a l...   Aug 15, 2009 - 2:49 PM
- - Bitter   just run standard denso plugs. so you have a misf...   Aug 15, 2009 - 5:36 PM
- - delusionz   Injector cleaner doesn't have a high explosive...   Aug 15, 2009 - 5:37 PM
- - samir0189   Low engine speed with high load. Only on 50%+ thro...   Aug 15, 2009 - 6:14 PM
- - Bitter   it starts up fine? do you have a good multimeter...   Aug 15, 2009 - 6:27 PM
- - samir0189   Starts fine, dont have any multimeter sadly. I nee...   Aug 15, 2009 - 6:30 PM
- - Bitter   well the voltage from the stock narrowband wouldnt...   Aug 15, 2009 - 7:25 PM
|- - samir0189   QUOTE (Bitter @ Aug 15, 2009 - 8:25 ...   Aug 16, 2009 - 6:57 PM
- - samir0189   Maybe this will help somebody later.. it was eithe...   Aug 21, 2009 - 3:59 PM
- - soulshadow   Seriously I drove with the same fuel filter on my ...   Sep 10, 2009 - 5:00 PM
|- - trdproven   QUOTE (soulshadow @ Sep 11, 2009 - 8...   Sep 16, 2009 - 5:28 PM
- - samir0189   I dunno, There is no real way to tell if it is cle...   Sep 10, 2009 - 8:17 PM
Lo-Fi Version Time is now: August 26th, 2026 - 5:54 AM
