Aug 13, 2009 - 4:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
drove the car round trip for 40mi this morning, no problem
Got in this afternoon, and had a slight sputtering? problem that has gotten worse and worse. ON throttle, i have really no power, the car sounds like its really straining, and the smell out the exhaust is very high in gasoline. Once i get it up to higher speeds (65+mph) it kinda goes away but its still there. I checked the plugs and wires, all is good. just bad gas? This post has been edited by samir0189: Aug 21, 2009 - 4:00 PM -------------------- ◊◊◊ My F/S Thread! ◊◊◊
samir0189 Bad fuel? --Fixed! Aug 13, 2009 - 4:01 PM
Bitter sounds like a misfire rooted in the ignition syste... Aug 13, 2009 - 6:55 PM
samir0189 I agree that is sounds like, and feels like a misf... Aug 14, 2009 - 12:28 PM
Bitter hows the cap and rotor? does the coil ohm out to ... Aug 14, 2009 - 7:34 PM
samir0189 Don't really know how to check all that Bitter... Aug 14, 2009 - 8:48 PM
Bitter grab a cheap ohm meter, i know the specs are avail... Aug 14, 2009 - 9:54 PM
samir0189 i wiggled the wires, nothing noticeable.
ALthoug... Aug 14, 2009 - 10:10 PM
Bitter bosch platinum spark plugs by any chance are whats... Aug 15, 2009 - 8:54 AM
samir0189 Yes, please dont remind me. Lol. Ive heard it tooo... Aug 15, 2009 - 8:58 AM
Bitter you should have stated that in the first post. cha... Aug 15, 2009 - 10:50 AM
samir0189 Some new NGK 7092 platinum tip plugs in there, no ... Aug 15, 2009 - 1:06 PM
samir0189 I just took it for a run, the new plugs helped a l... Aug 15, 2009 - 2:49 PM
Bitter just run standard denso plugs.
so you have a misf... Aug 15, 2009 - 5:36 PM
delusionz Injector cleaner doesn't have a high explosive... Aug 15, 2009 - 5:37 PM
samir0189 Low engine speed with high load. Only on 50%+ thro... Aug 15, 2009 - 6:14 PM
Bitter it starts up fine?
do you have a good multimeter... Aug 15, 2009 - 6:27 PM
samir0189 Starts fine, dont have any multimeter sadly. I nee... Aug 15, 2009 - 6:30 PM
Bitter well the voltage from the stock narrowband wouldnt... Aug 15, 2009 - 7:25 PM
samir0189 QUOTE (Bitter @ Aug 15, 2009 - 8:25 ... Aug 16, 2009 - 6:57 PM
samir0189 Maybe this will help somebody later.. it was eithe... Aug 21, 2009 - 3:59 PM
soulshadow Seriously I drove with the same fuel filter on my ... Sep 10, 2009 - 5:00 PM
trdproven QUOTE (soulshadow @ Sep 11, 2009 - 8... Sep 16, 2009 - 5:28 PM
samir0189 I dunno, There is no real way to tell if it is cle... Sep 10, 2009 - 8:17 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 5:43 PM |
