> Just did my keyring to blue..., wow that was a hastle, but it looks amazing
post Aug 21, 2009 - 2:26 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
I cut and stripped the wires on the stock light and then wired up 2 3mm led's with a 1k ohm 1/2 resistor to them, I'm impressed with my work to tell you the truth, it never turns out this nice the first try.
Replies (1 - 10)
post Aug 21, 2009 - 3:17 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
would a high output 5mm 74 led give the same result?? imma go install my 3mm 74 led tomorrow. nice job thumbsup.gif
post Aug 21, 2009 - 11:10 AM
richee3
Joined Jun 29, '08
From Denver
Seems like you did it the hard way. I simply pulled the factory bulb out and replaced it with a type 74 white LED. Only picture I happen to have of it here, but you get the idea. It took less than 5 minutes to get this.
This post has been edited by richee3: Aug 21, 2009 - 11:11 AM
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 21, 2009 - 11:19 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
see with my car the bulb was attached to a plastic housing then to 2 wires. The bulb and housing were 1 piece which i couldn't take the bulb out, I 'eventually crushed it and then realized it was just 1 piece so I just worked some magic and vuala
post Aug 21, 2009 - 11:24 AM
richee3
Joined Jun 29, '08
From Denver
Dang man, that sucks. Your car is a '97, mine is a '98, I wouldn't have thought they changed something like that. But now that you've described it, I know exactly what you are talking about. The ring that goes around my cigarette lighter was the same way.
EDIT: You have white gauge bulbs?
This post has been edited by richee3: Aug 21, 2009 - 11:24 AM
1998 Celica GT-
BEAMS Swapped.
post Aug 22, 2009 - 1:17 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
yea i swapped them out for 5way led 74 bulbs
http://superlumination.com/194.htm
look for 194 168 W5W 2825 Matrix Bulbs Emits Light in all Directions, that's the model number for the bulbs you need to replace the ones behind your gauges, strictly plug and play
post Aug 22, 2009 - 10:01 PM
richee3
Joined Jun 29, '08
From Denver
Yeah, I've swapped mine out for white LED's too. My dials still have a slight greenish tint to them, but the needles look great. How do you like your bulbs? I'm tempted to get those, since I bought 5-LED bulbs from v-leds.com and they all point straight forward. Granted, the light distribution is fine, no faded spots or anything, but I'm just hoping maybe your bulbs are better than mine about that green tint.
1998 Celica GT-
BEAMS Swapped.
post Aug 23, 2009 - 3:41 AM
Cavegod
Joined Jul 11, '09
From UK
just be greatful you didn't have the immobiliser!
http://www.celica-club.co.uk/forum/index.p...2128&st=140
post Aug 24, 2009 - 7:06 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
QUOTE (richee3 @ Aug 22, 2009 - 10:01 PM) *
I see no green tint whats so ever with mine biggrin.gif they're definitely worth it
QUOTE (Cavegod @ Aug 23, 2009 - 3:41 AM) *
ROFL wtf, you had to wire in a whole new led harness?
post Aug 24, 2009 - 7:16 AM
Cavegod
Joined Jul 11, '09
From UK
no thats the imobiliser all i did with th elight was swap the bulb for an led.
post Aug 24, 2009 - 5:36 PM
richee3
Joined Jun 29, '08
From Denver
Nice Freddy, I'll have to invest in those. I really don't like the green tint (it's not bad, but it's there) and I definitely don't want to sand the back of my gauges as some members here have done.
Cavegod, your light swap sounds the same as mine- simply pull the bulb out, put the LED in. I love it when things are that simple. Welshcelica (is that the right screen name? I know its Welsh Celica but I can't remember his exact screen name.) had the immobilizer on his car, and had to go through a huge ordeal to get the light ring. Lucky us!
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: August 31st, 2026 - 3:03 PM
