Aug 21, 2009 - 9:01 PM
Enthusiast ![]() ![]() Joined Nov 29, '07 From Colorado Currently Offline Reputation: 4 (100%) |
Long story short, I'm trying to get the correct tension on my timing belt, namely between the water pump and the cam(but obviously everything else).
I've got between the cams and the water pump as taught as I can get it, but it still seems looser than it should be(read, not 100% taught). So, any words of wisdom here or something? TiA! -------------------- 2019 M2, 2005 S2000, 1997 4Runne
Aug 22, 2009 - 12:48 PM
Anyone? I really could use some advice.
Aug 22, 2009 - 1:32 PM
Enthusiast ![]() ![]() Joined Jul 29, '07 From Quebec, Canada Currently Offline Reputation: 0 (0%) |
maybe you installed the belt wrong side of the tensionner?
This post has been edited by domyz: Aug 22, 2009 - 1:32 PM |
Aug 22, 2009 - 1:37 PM
I checked the diagram. The routing's all fine.
Aug 22, 2009 - 3:44 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
Is it completely loose? When i do timing belts i like to advance the cam gear one tooth. Then when i get the belt on retard it one tooth so that takes all the tension out and the left over tension should be taken out from the tensioner.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Aug 23, 2009 - 6:14 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
the tensioner pulley should have a spring that sets the tension in the belt.
you might have to check the spring to see if it's in good working condition. from How To Replace Your Timing Belt 15. Loosen the tensioner pulley bolt. Use a hard rod (like a socket extension for example) to push down on the part where the spring is hooked on to. Keep it down and retighten the pulley bolt. This loosens the tension in the belt. Remove the belt from the camshaft timing pulley. If you're reusing the timing belt only to replace the oil pump or water pump, then put a mark on the belt and timing pulleys to know where the belt should line up when you put it back on later. Click here to see an example. ![]() ![]() ![]() ... 21. Now that the belt is off, remove both tensioner and idler pulleys using a 14mm socket. Once off, inspect both pulleys to ensure they can freely rotate and don't wobble or have any cracks or anything. Also inspect the spring ensuring it meets factory specifications. I was only able to inspect the dimensions of the spring but not the tension force of the spring. I guess I can use Hooke's Law (F=kx) if only 'k' was given! LOL Nerds only: oh wait a sec, actually you can! if the range is 32 to 37 [N] while at 50.5 [mm] or 0.0505 [m] and since F=kx, then k=F/x. therefore, k(min) = 32 [N] /0.0505 [m] = 633.66 [N/m] and k(max) = 37 [N] / 0.0505 [m] = 732.67 [N/m]. (this is the theoretical ideal range for k). but you'll also need a known mass hanging on the spring and a ruler to measure its elongation (x) due to gravity. also calculate the force (F) by multiplying its mass by the gravitational acceleration. then solve for the actual value for k using k=F/x and compare if it falls in the theoretical ideal range for k. but i'm too lazy to actually do it, plus i'm on my summer break. no engineering til september! i'm gonna take my chances and skip the spring force test. meh, if the spring fails on me, then so be it. ![]() ![]() ![]() -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
| Lo-Fi Version | Time is now: September 15th, 2026 - 12:07 PM |
