Aug 22, 2009 - 1:15 PM
Enthusiast ![]() Joined Sep 6, '08 From Burlington Currently Offline Reputation: 0 (0%) |
Hey everyone,
I have a 94 and I have run into a problem. First time owner and not sure of any tricks with the brakes on these cars. My caliper bracket bolts are seized. The 14mm's in the rear and the 17mm's in the front. I was wondering if you know any tricks to get them out? I have tried penetrating oil, WD40, Rust Check and using an impact gun. Only other method I know is to heat them and crack them out. Any other ideas?? Please let me know. Going nuts, and have all the brake stuff ready to go on. Thanks in advance for your help. |
CelicaGTSboy23 Brake Caliper Brackets Aug 22, 2009 - 1:15 PM
808celica did you soak then in penetrating oil?? soaked mine... Aug 22, 2009 - 1:26 PM
CelicaGTSboy23 have tried to use a breaker bar... but no movement... Aug 22, 2009 - 1:31 PM
njccmd2002 there is one that freezes them and mini cracks the... Aug 22, 2009 - 1:44 PM
Remy PB blaster and long big breaker bar thats what I u... Aug 22, 2009 - 4:41 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 5:56 PM |
