> Right turn signal blowing up fuse
post Aug 24, 2009 - 5:07 PM
rheyx
Joined Apr 22, '08
when i make a right turn signal it keeps blowing up the fuse . left turn signal is ok and fuse is good.Some body have similar problem like this ? please help
post Aug 25, 2009 - 2:43 AM
IMTech1
Joined Jan 30, '09
From Anchorage, Alaska
if I am correct. it would be the power wire shorted to ground.
post Aug 25, 2009 - 3:31 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
mine did this for a bit, took out the tail lights and cleaned the wiring up a bit, replaced a bulb too i think and that was all.
does it blow if you put your hazards on?
ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s
post Aug 25, 2009 - 7:26 AM
rheyx
Joined Apr 22, '08
QUOTE (IMTech1 @ Aug 25, 2009 - 2:43 AM) *
mostly are they on the sockets? i tested them and they have continuity with the power off , are the sockets terminal ( positive and negative ) normally have continuity on them?
post Aug 25, 2009 - 7:31 AM
rheyx
Joined Apr 22, '08
QUOTE (Cuts_the_Pilot @ Aug 25, 2009 - 3:31 AM) *
i isolated the problem and its the right side tail lights specifically the turn lights thats causing the problem. i pulled off the harness of the tail light and tried to make a right turn signal ( just the front lights ) and it turn out ok.
Lo-Fi Version Time is now: August 31st, 2026 - 11:59 PM
