Aug 24, 2009 - 8:04 PM
Enthusiast ![]() ![]() ![]() Joined Sep 22, '08 From Bergenfield Currently Offline Reputation: 5 (78%) |
**** NOVEMBER 18, 2009....I HAVE ANOTHER WRC GEN3 ST205 3SGTE COMPLETE MOTOR SET UP FOR SALE****
Up for sale is one of my WRC GEN3 ST205 3SGTE COMPLETE Motor sets. There is nothing wrong with this motor set, its just I need to start making some room. I currently have 4 complete motor sets and its just time for one to go. I have gone through this motor set ensuring that EVERYTHING is there. There are no missing parts on this motor set. Motor set includes: WRC GEN3 ST205 3SGTE motor AWD transmission Uncut wiring harness ECU ALL the accessories Intake Manifold COMPLETE W2A IC kit Ignitor Map sensor etc. Unlike Importers who dont know the 3SGTE and will sell off "complete" motor sets that are from complete....this set has EVERYTHING! Price 2600 shipped With W2A IC system 2200 shipped with out W2A IC system for those wanting to go FMIC ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Price 2600 shipped With W2A IC system 2200 shipped with out W2A IC system for those wanting to go FMIC ST_205 front clip with awd parts Price : 4800 shipped with the rear AWD parts. 4300 shipped without the rear AWD parts. Pictures: ![]() ![]() ![]() ![]() This post has been edited by _Jim_: Nov 29, 2009 - 4:43 PM --------------------
Aug 24, 2009 - 11:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Isn't that pretty damn cheap? Good luck with the sale.
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Aug 24, 2009 - 11:37 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
thats amazingly cheap haha...WRC is rare as F!ck....GL with the sale jim
This post has been edited by CelicaST_CALI: Aug 24, 2009 - 11:37 PM -------------------- BANNED. for life, you moron.
Aug 25, 2009 - 3:38 PM
I have been getting a lot of PM's about the differences between the WRC GEN3 ST205 and the standard GEN3 ST205
I copy and pasted this from my build thread (http://www.6gc.net/forums/index.php?showto...20&start=20): The WRC and the standard ST205 are identical in almost every way except for the fact the WRC has a lot more goodies on it. A WRC came with factory water injection, factory intercooler/heat exchanger sprayer, Antilag system, heat "protection" piece between the header and the TMIC, the hood comes stock with the hood spoiler. The Water injection, intercooler/heat exchanger sprayer, and the anti lag system all come inactive in the street version of the WRC, and only the race car had the ECU to control all of these features. But that doesn't mean we cant get them to work The factory water/meth injection nozzle (which looks like a GEN2 Cold Start Injector) comes Installed into the bottom of the throttle body on the WRC edition, which is going be a big help in getting my devils own kit to work on the GEN3. Manny will get a better look at it when he has the motor up there. The problem with the standard ST205 is that when trying to install the nozzle of the devils own kit, you need to install it between the intercooler and the throttle body. The problem here is that the only place to install the nozzle is about 2 inches long and is made of rubber The factory intercooler/heat exchanger sprayer also comes inactive on the WRC street car, but I should be able to get around that as well with very little work. The intercooler/heat exchanger sprayer is mounted on the inside of the JDM crash bar, it comes with 3 nozzles pointed at the heat exchanger all on a continuous line that runs to the window washer tank. You cant believe the amount of stuff that is on the WRC window washer fluid tank, it has more wires, pumps, hoses, etc. I believe I read somewhere that the pump for the intercooler/heat exchanger sprayer is a working pump (which also supplies fluid for the water/meth injection), and all that is required to get it working is to wire it in. Well I couldn't find information on when it comes on, how long it sprayers for, or even if it does spray with out a switch. All that I read was that it could be wired in, but made no mention of to control the spray. Realistically I will only need the intercooler/heat exchanger sprayer to work when I am at WOT and wanting to cool the intake charge as much as possible. So based on the lack of information on the factory pump, I will install a new pump in place of the factory pump and connect all the factory lines that go the intercooler/heat exchanger sprayer to the new pump. As for wiring I will tap the power source for the pump to the wire off the Devils Own kit that sends power to the water injection pump so that way I only use the intercooler/heat exchanger sprayer when needed at WOT. So basically when the water injection starts spaying at 11psi, so will the intercooler/heat exchanger sprayer. As far as the antilag system goes, I am not going to fool around with that for now because I really don't have a need for it. The pea shooter ct20b spools plenty fast on its own and doesn't need any help. I have some ideas for the antilag, but they aren't going to come into play until I am ready to upgrade to a bigger turbo. And no, not all antilag systems will destroy turbos. Many EVO's use antilag and hold up just fine turbo/motor. I will do more research on this to see what makes the EVO antilag system less harsh compared to other systems. I obviously cannot use the antilag system like the WRC race car had, but with the plumbing in place, I do have a few options. Just need time, and a bigger turbo to make it all worth considering. In due time. The WRC GEN3 ST205 also comes with a Steel wheel CT20B, which is less likely to fatigue/fail as compared to its Ceramic cousin (Standard Ceramic CT20B found on the Standard GEN3 ST205). It can also handle Higher boost MUCH more safely then the Cearmic CT20B found on the Standard GEN3's --------------------
Aug 25, 2009 - 3:45 PM
For a shorter version, the differences are:
Steel Wheel CT20B Factory water injection Added heat protection for the W2A IC Antilag system installed, by inactive Rumors of the WRC that I have yet to confirm or deny: More aggressive ECU Stronger AWD transmission On my BONE STOCK WRC GEN3 Swap, I made 330WHP (about 400bhp) and 310WTQ at 21psi with nothing more then Intake, exhaust, Boost controller, and water injection. --------------------
Aug 25, 2009 - 7:19 PM
Enthusiast ![]() ![]() ![]() Joined Jan 10, '09 From Burtonsville, Maryland Currently Offline Reputation: 1 (100%) |
dibs on this as well.. pm sent
-------------------- THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma.. 6gc.net's outlaw vigilante because im a LEADER not a follower. ![]() |
Aug 25, 2009 - 7:47 PM
PM replied
Aug 27, 2009 - 11:06 AM
Do you own, jdm engine depot? LOL. If you have this in the next 2 months LMK. Dont have money right now, plust torn between this and a beams...
Aug 28, 2009 - 2:34 AM
Enthusiast ![]() Joined Sep 25, '08 From california Currently Offline Reputation: 1 (100%) |
i will take it if you install it for me lol.
Aug 30, 2009 - 1:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
God i need to start saving my money. I've been wanting and needing a 3s for so long.. But can't seem ta save any money lol.. Well if this is still for sale in the next couples months i might just have ta take it..
Aug 30, 2009 - 3:00 PM
Enthusiast Joined Apr 12, '09 From Brooklyn NY Currently Offline Reputation: 0 (0%) |
you accepting payments
Sep 1, 2009 - 3:17 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 5, '06 From San Luis AZ Currently Offline Reputation: 4 (100%) |
man check your pms,,, i have sent you 2 already and no answer......
Sep 1, 2009 - 12:08 PM
guys he's currently selling this set to me.. transaction should be finished in a few days.
Sep 2, 2009 - 2:33 AM
you gotta be kidding me man!!! u sure
i wanted it so bad! -------------------- ![]() |
Sep 3, 2009 - 5:14 PM
JIM!!! GET ONLINE SO I CAN BUY THIS MOTOR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 3, 2009 - 5:37 PM
hahaha, NP man.
Sep 5, 2009 - 7:56 AM
hey Jim it went through.. im 3Gs shorter in my balance lol.
Sep 12, 2009 - 4:12 AM
Enthusiast Joined Aug 27, '09 From caifornia Currently Offline Reputation: 0 (0%) |
i knew it looked familiar, I almost bought it when it was still on ebay
This post has been edited by lalojamesliz: Sep 12, 2009 - 4:14 AM |
Nov 18, 2009 - 7:19 PM
see first page/post for details and pricing. --------------------
Nov 27, 2009 - 5:21 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 18, '07 From Bergen county NJ Currently Offline Reputation: 24 (100%) |
pictures of the clip :
| Lo-Fi Version | Time is now: August 11th, 2026 - 9:06 PM |
