> Clutch Problem 94 ST
post Aug 29, 2009 - 11:43 AM
tataycelica
Joined May 9, '08
From New Jersey
I'm planning to trade my car with a 94 st. The owner replaced the clutch with stage 1. If you step on the clutch and hold it for 5 seconds it won't allow me to shift. I have to turn off the engine to be able to shift. But it shifts fine as long as you won't hold the clutch with that span of time. Any suggestions is greatly appreciated. Thanks!
post Aug 29, 2009 - 11:52 AM
legalkid86
Joined Dec 14, '08
From RGV, Texas
QUOTE (tataycelica @ Aug 29, 2009 - 11:43 AM) *
clutch gone bad???
wAkE uP, u'Ll sLeEp WhEn U DiE.....
post Aug 29, 2009 - 12:22 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
I don't know much about what it could be but, i'd look and see if the slave is working correctly, maybe something to do with the pressure plate? just a thought
2nd Gen 3s-gte.... It lives!
97celiman
post Aug 29, 2009 - 12:53 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
sounds like either the master or slave cylinder is bleeding out pressure, is it loosing clutch fluid? if not then its probably an internal leak within the clutch master cylinder. if it is leaking out well then duh, find where its leaking out and fix it.
post Aug 29, 2009 - 3:07 PM
tataycelica
Joined May 9, '08
From New Jersey
Ok. Thanks for the suggestions.
Lo-Fi Version Time is now: July 30th, 2026 - 4:03 PM
