Aug 29, 2009 - 8:46 PM
Enthusiast Joined Aug 29, '09 From Ohio Currently Offline Reputation: 7 (100%) |
Does anybody know how to get to the rear quarter panel window motors. I just got a 97 GT Convertible and the rear windows don't work. The switches are good, so it is either the wiring or the motors. I have taken apart the back quarters and looked behind the speakers and the seat belt tensioners, but haven't found the window motors. Also wondering if anyone knows where to get the weatherstripping which goes between the rear glass and the door glass.
Thanks |
Aug 29, 2009 - 9:20 PM
Aug 29, 2009 - 9:33 PM
Thanks for the reply. That is a great link. Do you have any good sources for parts?
Aug 29, 2009 - 10:59 PM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
njccmd2002 has most things right in that procedure. However:
You don't need anything special to unscrew the large washer-nuts holding the glass to the plate. Channellocks work just fine. The rubber seal between rear glass and door glass is not sold separately. It's part of the rear glass and glued permanently. |
Aug 29, 2009 - 11:02 PM
1sttoyotaparts.com
any tools help, thats what i had atm -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Aug 29, 2009 - 11:55 PM
Deleted. Double post.
This post has been edited by dgbldr: Aug 29, 2009 - 11:56 PM |
Aug 30, 2009 - 12:06 AM
Enthusiast Joined Jul 8, '09 From Missouri Currently Offline Reputation: 0 (0%) |
Got the same issue with my driver side quarter.... How did you determine that the motor was bad/good? Mine seems to be too far forward causing the front door glass to bow out slightly at the top. I don't hear anything when I press the driver side switch. The passenger goes up and down just fine.
I need to figure out how to either get the glass permanently down, or at least be able to push it up or down manually for now. I am not going to pay $450 for a motor from Toyota, plus whatever labor to put it in. Let us know what you decide to do..... |
Aug 30, 2009 - 6:12 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
lol when i read this thread i though you where trying to get the rear quarters on a hatch to roll down
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Aug 30, 2009 - 6:36 AM
I figured out it was the motor when I downloaded the electrical scheme. I had power to the front panel switch, I tested the switch and it gave 12v from Pin 1 to 3 and then pin 2 to 3 when I pressed the up and down and when I put the 12 volts to the motor circuit it didn't work. I haven't gotten the motor out yet, but once I get to the motor I will see if 12 volts is getting there, if it is then my motor is toast.
Sep 13, 2009 - 10:46 AM
Enthusiast ![]() ![]() Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
I figured out it was the motor when I downloaded the electrical scheme. I had power to the front panel switch, I tested the switch and it gave 12v from Pin 1 to 3 and then pin 2 to 3 when I pressed the up and down and when I put the 12 volts to the motor circuit it didn't work. I haven't gotten the motor out yet, but once I get to the motor I will see if 12 volts is getting there, if it is then my motor is toast. If one switch goes bad it could affect both quarters. I cleaned the switch when my quarter window stopped and the quarter works perfect again. The way to clean it is in the how to's somewhere. |
Sep 14, 2009 - 12:57 PM
Thanks for the help. I used the how to to clean the switch and still no go. I have ordered a new motor from 1sttoyotaparts, but it was $$$$. I'll post once I get this fixed. Hopefully get the parts this week.
AJ I figured out it was the motor when I downloaded the electrical scheme. I had power to the front panel switch, I tested the switch and it gave 12v from Pin 1 to 3 and then pin 2 to 3 when I pressed the up and down and when I put the 12 volts to the motor circuit it didn't work. I haven't gotten the motor out yet, but once I get to the motor I will see if 12 volts is getting there, if it is then my motor is toast. If one switch goes bad it could affect both quarters. I cleaned the switch when my quarter window stopped and the quarter works perfect again. The way to clean it is in the how to's somewhere. |
Sep 14, 2009 - 1:17 PM
before ordering the motor you should have tested the old one, did you test the relay, cant remember where it is located.
| Lo-Fi Version | Time is now: September 15th, 2026 - 12:24 PM |
