Aug 30, 2009 - 11:49 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 10, '08 From sweet home, OR Currently Offline Reputation: 3 (100%) |
i got a pair of sparco jr's but i just have them what brackets/mounts can i get thatl go right on??
http://www.andysautosport.com/toyota/1994_...ar00143312.html will those just bolt right on too the floor? and than get 2 of the universal sliders? help!!! This post has been edited by terbear4god4life: Aug 30, 2009 - 12:51 PM -------------------- |
Aug 30, 2009 - 1:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
You can order a set of Corbeau seat brackets. They come with sliders installed, and are $99 each. They'll sit lower than those sparco ones as well.
edit: The Corbeau ones bolt right to the OEM mount locations, but on one of mine I had to cut a bit out because they were off by just a hair. No big deal. This post has been edited by 95CelicaST: Aug 30, 2009 - 1:06 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Aug 30, 2009 - 2:08 PM
Enthusiast ![]() ![]() ![]() Joined Jul 2, '08 From SoCal Currently Offline Reputation: 6 (100%) |
one thing a lot of people don't realize is that there are a lot of things that you will need to purchase other than the seat to be able to install them into your car. typically on racing seats you are going to need the seat base (car specific), sliders (if you want to be able to move the seat, but not mandatory), and the side brackets, as well as all the hardware to attatch everything. if you want to stick with sparco stuff, here's the parts you would need.
seat bases: http://www.sparcousa.com/pseats_acc.asp?id=678 side mounts(there are more than one, so i just put the steel ones): http://www.sparcousa.com/pseats_acc.asp?id=153 sliders(optional): http://www.sparcousa.com/pseats_acc.asp?id=156 |
Aug 30, 2009 - 9:37 PM
You can order a set of Corbeau seat brackets. They come with sliders installed, and are $99 each. They'll sit lower than those sparco ones as well. edit: The Corbeau ones bolt right to the OEM mount locations, but on one of mine I had to cut a bit out because they were off by just a hair. No big deal. ok will do are these the ones i need? http://www.andysautosport.com/toyota/1994_...racket/corbeau/ -------------------- |
Aug 30, 2009 - 10:42 PM
Yep, those are the ones. They don't look like the ones in the picture, but those are the part numbers.
Aug 30, 2009 - 11:28 PM
Yep, those are the ones. They don't look like the ones in the picture, but those are the part numbers. alright kewl i got both the seats for 185 with weapon r harnesses ( not the chepo ones)=p This post has been edited by terbear4god4life: Aug 30, 2009 - 11:28 PM -------------------- |
Sep 1, 2009 - 9:02 PM
Yep, those are the ones. They don't look like the ones in the picture, but those are the part numbers. alright kewl i got both the seats for 185 with weapon r harnesses ( not the chepo ones)=p you gonna get a harness bar? |
Sep 1, 2009 - 9:16 PM
Tigawoods has my old harness bar. You should see if he'll pull it out and have a couple made.
Sep 2, 2009 - 10:17 AM
Enthusiast ![]() ![]() ![]() Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) |
I'd suggest to get brackets and sliders directly from Sparco USA website. I got mine there and with only one minor issue they worked like a charm.
-------------------- '94 ST |
Sep 2, 2009 - 1:40 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
i have a passanger Corbeau bracket if your interested its brand new
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Sep 7, 2009 - 7:17 PM
![]() Enthusiast ![]() Joined Aug 9, '09 From Green Cove Springs Currently Offline Reputation: 3 (100%) |
hey what if you bought cheap bomz racing seats, would i need specfic sliders? i need some help.
Sep 7, 2009 - 8:19 PM
If you bought cheap bombz seats then you should sell them. They're not going to hold up in a crash.
Sep 7, 2009 - 9:31 PM
Sep 7, 2009 - 9:43 PM
If you bought cheap bombz seats then you should sell them. They're not going to hold up in a crash. i dont have a job so bomz is gonna have to do,but i have to buy sparco seat brackets for $200 so thats great if saving some money now and being crippled is ok with you, then thats your choice. personally, if i were you, i would wait until you can afford reputable seats and stick with the stock seats until then. also why spend more in the long run and have some POS seats when you would actually save money in the long run by just saving the cash and getting sparcos the first time? |
Sep 8, 2009 - 12:01 PM
If you bought cheap bombz seats then you should sell them. They're not going to hold up in a crash. i dont have a job so bomz is gonna have to do,but i have to buy sparco seat brackets for $200 so thats great if saving some money now and being crippled is ok with you, then thats your choice. personally, if i were you, i would wait until you can afford reputable seats and stick with the stock seats until then. also why spend more in the long run and have some POS seats when you would actually save money in the long run by just saving the cash and getting sparcos the first time? cause im stupid ur right these seats feel like there made of cardborard ill save up. |
Sep 8, 2009 - 1:03 PM
If you bought cheap bombz seats then you should sell them. They're not going to hold up in a crash. i dont have a job so bomz is gonna have to do,but i have to buy sparco seat brackets for $200 so thats great if saving some money now and being crippled is ok with you, then thats your choice. personally, if i were you, i would wait until you can afford reputable seats and stick with the stock seats until then. also why spend more in the long run and have some POS seats when you would actually save money in the long run by just saving the cash and getting sparcos the first time? cause im stupid ur right these seats feel like there made of cardborard ill save up. good choice. just hate seeing people waste their money on crappy products and spend way more money than if they would have bought the right thing in the first place. i'm a cheap ass, but there are things i will not go cheap on, like seats, race suits, engine parts, and the like. trust me, you will be way happier when you get the nicer seats. |
Sep 8, 2009 - 1:26 PM
If you bought cheap bombz seats then you should sell them. They're not going to hold up in a crash. i dont have a job so bomz is gonna have to do,but i have to buy sparco seat brackets for $200 so thats great if saving some money now and being crippled is ok with you, then thats your choice. personally, if i were you, i would wait until you can afford reputable seats and stick with the stock seats until then. also why spend more in the long run and have some POS seats when you would actually save money in the long run by just saving the cash and getting sparcos the first time? cause im stupid ur right these seats feel like there made of cardborard ill save up. good choice. just hate seeing people waste their money on crappy products and spend way more money than if they would have bought the right thing in the first place. i'm a cheap ass, but there are things i will not go cheap on, like seats, race suits, engine parts, and the like. trust me, you will be way happier when you get the nicer seats. thanks man i'm deff. thinking before i buy something cheap again. |
Sep 8, 2009 - 1:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
you can get something like these for a budget friendly and reliable set-up
CLICK ! I have those same seats in my car, I got mines in far better condition with the Evo tracks on them for 300, then buy brackets and install, easy and for under 600 you can have recaro seats in your celi. This post has been edited by Culpable04: Sep 8, 2009 - 1:47 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: August 31st, 2026 - 3:05 PM |
