Oct 25, 2003 - 1:24 AM
Enthusiast ![]() Joined Mar 18, '03 From Quebec Currently Offline Reputation: 0 (0%) |
Yo!
I plan to do the big swap(3SGTE) in my Celica 94 ST(7AFE). Everybody talk about How To do the swap, but my question is about supension and braking.. Does my current suspension(OEM) and Brake (OEM Front disk and OEM rear Drum) is enought for the 3SGTE? Does is the same suspension between AT200 and STxxx? If I Need to change my suspension, What is your suggestion?And about brake? What is the weight of this engine 3SGTE, 5SFE, 4AGE, 7AFE?(this part of the topic is to help the Search button!) Thanx for your help! P.S. I try the search button, but I find nothing... |
Oct 25, 2003 - 9:48 AM
Your suspension components will be fine, but I'd try to upgrade to rear disk brakes in the back, so that you'll have better braking performance. Good luck though, I've tried to buy them from three different people, and it never goes through for one reason or another.
Oct 25, 2003 - 12:19 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
The ST and GT suspensions are different. the STs suspension is made for a lighter load, although it will work fine, eventually upgrading is definatly a good idea.
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
| Lo-Fi Version | Time is now: August 26th, 2026 - 10:11 PM |
