> Leakdown/Compression Test (2nd Gen 3sgte), Results.. need some advice
post Sep 3, 2009 - 10:44 PM
markie
Joined Aug 6, '05
From cerritos, california
Compression Test:
170/175/175/170
Leak Down:
30/30/30/20
The car has been sitting for the good part of almost 2 years. It is turned on roughly once a month and driven even less.
So, I've been doing my research and I have heard that 20% leak down is marginal, and anything above 20% is a definite warning sign for trouble.
What should my expectations be for the motor at this point as far as how long is it going to last me? Are there ways to salvage what's left of the motor/prolong its life?
This post has been edited by markie: Jan 15, 2010 - 2:28 AM
things happen for a reason.
post Jan 15, 2010 - 2:30 AM
markie
Joined Aug 6, '05
bump
post Jan 15, 2010 - 3:02 AM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (markie @ Jan 15, 2010 - 3:30 AM) *
bump
i wouldn't say its a huge issue, as our cars tends to have small leaks. the only thing that would be a huge issues is the head gasket (500$ish replacement if sum1 does it for u) DIY for 100$ish
depends how u drive it, compression is still good, headgasket cant be bad.
even my 5s-gte after less than 500 km 190/190/195/190 , 25/25/25/25
This post has been edited by Mstoochn: Jan 15, 2010 - 3:06 AM
post Jan 15, 2010 - 8:22 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Mstoochn @ Jan 15, 2010 - 3:02 AM) *
bump
those are good compression numbers... is the leakdown cylinder leakage i suppose?
post Jan 15, 2010 - 7:11 PM
markie
Joined Aug 6, '05
I'm not sure, I'm planning on having another shop do another leak down and see if they can pin-point where the leak is coming from.
post Jan 15, 2010 - 9:45 PM
epocsirhc
Joined Nov 8, '08
From Penn Valley,Ca
The compression numbers are quite close which is a good thing. As far as leak down, no motor has a perfect seal and like you said 20 is marginal.
Lo-Fi Version Time is now: August 25th, 2026 - 1:43 AM
