Sep 5, 2009 - 2:40 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jan 10, '06 From Mozambique, Africa Currently Offline Reputation: 8 (100%) |
Today I decided to relocate my battery. I'm a novice with electrics so I was a bit hesitant about doing it, but all came out fine and I'm pretty pleased with myself.
Before: ![]() More painful moments of drilling holes into my car. ![]() ![]() I didn't jack the car up or I would have noticed that I could have run the cable through the plastic guard instead of tiestripping it to it. Oh well. Project for another day. ![]() ![]() Finished product! ![]() And, TA-DAAA! More space? For what, I don't know. But I'll think of something.
-------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Sep 5, 2009 - 2:45 PM
Enthusiast ![]() ![]() ![]() Joined Mar 26, '09 From Minnesota Currently Offline Reputation: 5 (100%) |
More space for a gt42r and custom ic piping
-------------------- "God created turbo lag to give V8's a chance"
Sep 5, 2009 - 3:02 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
what about one of these?
Sep 5, 2009 - 3:42 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Now drill out the spot welds and get rid of the battery tray, then weld up the holes.
Sep 5, 2009 - 4:02 PM
Now drill out the spot welds and get rid of the battery tray, then weld up the holes. heh..i was thinking that very thing when i saw the pic. if your careful with a spot weld cutter, you wont even have any holes to weld, just grind the spot welds flat. -------------------- Former Team 5SFTE pro member ;)
Sep 5, 2009 - 4:24 PM
Now drill out the spot welds and get rid of the battery tray, then weld up the holes. heh..i was thinking that very thing when i saw the pic. if your careful with a spot weld cutter, you wont even have any holes to weld, just grind the spot welds flat. What, you mean like with an angle grinder? -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Sep 6, 2009 - 11:51 AM
Now drill out the spot welds and get rid of the battery tray, then weld up the holes. heh..i was thinking that very thing when i saw the pic. if your careful with a spot weld cutter, you wont even have any holes to weld, just grind the spot welds flat. What, you mean like with an angle grinder? yup. use this to cut the welds: http://www.harborfreight.com/cpi/ctaf/disp...temnumber=95343 just go slow, and just cut thru the top layer of steel, then pop the bracket loose, and grind the welds flat with an angle grinder, or a die grinder with a sanding disk or whatever. -------------------- Former Team 5SFTE pro member ;)
Sep 7, 2009 - 12:23 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Hey dude, I don't know how safe it is to run that positive cable underneath the car like that, I had lifted my carpet and tucked it underneath.. underneath the rear seats, behind the rear speaker plastics, thru underneath the carpet by the door sill and up through the firewall loom rubber boot i put a 12mm hole in it.
Also its best if you run 2 ground cables, one to the chassis at the back and the other to the original bolt on the engine block. -- We had cold start troubles after having an immobiliser alarm installed, due to not grounding at the engine. adding in this ground to the engine solved the problem. -------------------- Mike W
Sep 7, 2009 - 1:11 AM
Hey dude, I don't know how safe it is to run that positive cable underneath the car like that, I had lifted my carpet and tucked it underneath.. underneath the rear seats, behind the rear speaker plastics, thru underneath the carpet by the door sill and up through the firewall loom rubber boot i put a 12mm hole in it. Also its best if you run 2 ground cables, one to the chassis at the back and the other to the original bolt on the engine block. -- We had cold start troubles after having an immobiliser alarm installed, due to not grounding at the engine. adding in this ground to the engine solved the problem. Thanks! I had read about the cold start issue before. If you look at the 5th picture, you'll notice right by the cone filter, the tip of my engine bay ground that used to be the original negative terminal. I'll probably end up doing what you suggested with the positive cable just to give it a cleaner look. Thanks for the tips! -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Sep 7, 2009 - 12:26 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Wow - great work Slick! That looks great!
Sep 14, 2009 - 11:47 AM
Ok, problems already. I decided to take celi to work today and it was fine in the morning. On the way back home this evening, I had the headlights on, and when I pressed the brakes, the lights would dim a little and then return to norml. And when I turn the high beams while driving the car almost shuts off.
Do I need to add another ground? -------------------- ![]() "Remember, amateurs built the ark and professionals built the Titanic. But revolutionaries built the Celica!"- Me |
Sep 14, 2009 - 10:20 PM
use 4g wire and ground your tranny (or block) to the chassis and the alternator to chassis too (replace the stock one).
make sure there is a soild/CLEAN connection here in this pic ![]() and make sure your + connections are secure. -------------------- |
| Lo-Fi Version | Time is now: July 29th, 2026 - 4:02 PM |
