Sep 29, 2009 - 7:42 PM
Enthusiast ![]() ![]() ![]() Joined Feb 14, '09 From Mid West Currently Offline Reputation: 7 (100%) |
Hey Culpable04--Can I bring my Celi by for you to mod?
I want true HIDs,custom grill work,BIG A#S breaks,17 inch wheels,........ It's all good--- Some day... |
Sep 30, 2009 - 12:01 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
so if I have big enough rims I'd only need 2x 3mm spacers 1 for each front right?
how close are we talking for the ball joint?? -------------------- |
Sep 30, 2009 - 4:05 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
GT4 brakes easier to get into SS-III than SS-II because of superslut? I read somewhere st205 superstrut is just as different to st202 superstrut as it is to st202/st204 macpherson , I could believe that too.
-------------------- Mike W
Sep 30, 2009 - 9:55 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) |
Rusty,
not Big enough wheels but the correct offset, with my wheel design now I have a 27 off set ( 42 - 15 mm spacer ) this will vary depending on the spoke design on your wheel, but yes, as long as your wheels can clear the calipers without spacers, all you'll need is the 3 mm spacer for the rotors. delusionz It is my understanding that if you have a SS III with superstrut suspension, all you need is to swapp the front knuckles to make the brake set-uip a copmplete bolt on. the knuckles are slightly different to accomodate for the different brake set-ups. so swap them and you will be golden. -------------------- ![]() |
Sep 30, 2009 - 10:11 AM
GT4 brakes easier to get into SS-III than SS-II because of superslut? 27 offset, aint that pushing it more out than the 45 offset? cuz i have 45, and if 27 did not clear it, doubt 45 will. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Sep 30, 2009 - 10:54 AM
27 mm is the resulting offset
42 is the offset of my wheels, then you add the spacers ( in my case 15 mm ) the spacer size is substracted from the wheel offset so we have 42 - 15 = 27 and yes, as you add the spacer it pushes the wheels out, thus clearing hte calipers and being more flushed witth the body ( or sticking out if you go too far ) This post has been edited by Culpable04: Sep 30, 2009 - 10:55 AM -------------------- ![]() |
Sep 30, 2009 - 4:04 PM
Enthusiast ![]() Joined Apr 15, '08 From suffolk,UK Currently Offline Reputation: 0 (0%) |
so can this be done to a uk spec gt st202 with no ss suspension?
Sep 30, 2009 - 4:13 PM
Yes
Sep 30, 2009 - 6:36 PM
delusionz It is my understanding that if you have a SS III with superstrut suspension, all you need is to swapp the front knuckles to make the brake set-uip a copmplete bolt on. the knuckles are slightly different to accomodate for the different brake set-ups. so swap them and you will be golden. The thing that is puzzling me is that ST202 SS-II and SS-III have Identical brakes, One being MacPherson and the other being Superstrut, They both need the 2pot stopping power because they both have 3S-GE engines. So I don't see how ST202 superstrut should make GT4 brake fitment any easier than any SS-I, SS-II, USDM GT or UK GT being they all share the same macpherson suspension, or do they? The only advantage I can see with the SS-III is that they have identical OEM alloy wheels to the GT4 therefore the correct clearance is already there -------------------- Mike W
Sep 30, 2009 - 7:15 PM
SS-III with superstrut has a different knuckle than the gt4 to acomodate the 2 piston brakes, if you use a gt4 knuckle, then the gt4 brakes will bolt on, as all your front suspension will be now identical to gt4.
Again, the only diference between the 4 and ss-iii is the knucle. Swapped the knuckle and bolt the brakes on -------------------- ![]() |
Oct 31, 2009 - 12:37 AM
confused again
QUOTE (Culpable04) if you decide to go with Cadillac Catera disk, you'll need to use a 3 mm spacers on te hub to push the disk out and be in line wiht the center line of the calipers, basically that's it you'll need brake pads spacers, I used the old pads with all the brakes component sanded off. the brake pad spacer needs to be 2 mm thick and goes on eahc side, this is because the cadillac disk is 28 mm thick, and the ST205's are 32 mm thick. QUOTE (Culpable04) Rusty, not Big enough wheels but the correct offset, with my wheel design now I have a 27 off set ( 42 - 15 mm spacer ) this will vary depending on the spoke design on your wheel, but yes, as long as your wheels can clear the calipers without spacers, all you'll need is the 3 mm spacer for the rotors. ok I have a set of correct offset rims (trust me I do However for the rotors to fit you require them to be 297mm or smaller? I dont suppose there are a set of 297mm by 32mm thick rotors? Is it safe to take the 18mm off the standard rotors to get to 297mm rotors? Other parts required to for these to work: 3mm wheel spacers (1 for each front wheel) the longer stainless steel brakelines and the calipers need to be tap and threaded. The caliper required to some work aswell? -------------------- |
Nov 2, 2009 - 9:50 AM
sorry for taking long,
if you are trying to do this conversion using ST205 rotors, you'll have to follow the previously made post, as I didn't use ST205 disc there are small diferences on the installation. the rotors can be anywhere from 297 mm to 300 mm I previously said 297 wouldn't work, but later we realize that I was using a 5th gen knuckle for test fitments and is slight diferent than a 6th gen knuckle,. 297 mm will put you right at the end of the pads, pad and rotor will meet perfectly at the end, so if you want a little extra disc go with 300 mm. you won't need the small spacer for the disc, using ST205 disc, but I don't remember all the details so look for the post and follow it, maybe pm lubu for questions. if you go with the Cadillac Catera disc, trhen I'll be here to guide you throught it. -------------------- ![]() |
Nov 4, 2009 - 2:55 AM
Hmm Lubu hasn't been on since August, the things I dont like are the spacers between the calipers & the grinding down of the caliper. The other thing I haven't checked is would I be able to get a LLVTA cert (In NZ you have to get certain mods certified like: adjustable suspension, + Turbo, + engine cc/ + cylinders, roll cages etc)
Nov 4, 2009 - 7:22 AM
Hmm Lubu hasn't been on since August, the things I dont like are the spacers between the calipers & the grinding down of the caliper. The other thing I haven't checked is would I be able to get a LLVTA cert (In NZ you have to get certain mods certified like: adjustable suspension, + Turbo, + engine cc/ + cylinders, roll cages etc) with the ST205 rotors you will still need to grind the caliper down. the reason why I needed a 3 mm on the back of the rotor is because the disc would touch the ball joint without it. if you are not in a rush, let me look and see if there is other rotor that you can use without the spacer on the back. but you will definately need to grind the caliper bracket, no way around that unless you do a SS III suspension conversion, the offset needed for the rotor to be center with the caliper is too deep and will hit the ball joint when driving. -------------------- ![]() |
Nov 4, 2009 - 11:32 AM
Yea I understand culp, will also talk to guys on whether I would be able to get these certified.
Jan 4, 2010 - 12:44 PM
note to anyone doing this
buy new brake shims ( supra TT ) along with the pads. may seem basic but with all the excitement of completing this, I forgot to buy new ones when installed my pads, so you can just imagine how they sounded like, finally saturday I got the shim kit ( US$21.00 from the dealer ) and installed it Sunday, quiet and firm brakes, I coudln't be happier with the result of this. is not as hard as it may look once you have all the parts is just as hard as a regular brake job. If it wasn't so cold out I would do some 60 - 0 tests to get some performance numbers to compare with the stock brake system, but that will have to wait for better weather and bettter going power. I guess eventhough I had the bad brake noise due to lack of shims, is also good to mention that all this time I've been driving my car with these brakes and other than the noise, no isses have been developed or noticed, Hopefully a few more of you go this route instead of BBK for 1k or more, I agree with those who think the stock brakes do a good job, but the extra stopping power is not bad to have, specially if your car is accelarating faster than is was meant to. These brakes will come handy for auto X and road course in the spring time. -------------------- ![]() |
| Lo-Fi Version | Time is now: August 9th, 2026 - 3:35 PM |
