> 3vz-fe V6, 5th gen....., my conversion
post Sep 8, 2009 - 11:19 PM
fibrewizard
Joined Sep 8, '09
From australia, east coast
hi guys ..... been wanting to join here for a while now....
and finally got around to doing it.....
i didnt want to step on any toes seeing as though i own a 5th gen, .....
however i thought you might be interested to hear about my conversion......
i am aware that a member on here has done a V6 conversion and alot of his details i have used for mine....
so i would just like to say thanks.......
so here we are.......
hi.....
well now that i have introduced myself.... i thought id share my build with you all.......
1991 st184sx Celica.......
bought it stock as a rock... no mods at all....
1st thing i did was rims and exhaust...
then i got thinking about a 3sgte conversion.... but that was too obvious.... i am always in my head thinking about different ways to do things and going with a generic engine swap was to plain for me......
after about 1 yr of researching and saving.... i decided to swap in a 3vzfe quad cam V6 out of a 96 vdv10 camry...
so next step was to gather all the bits id need and plan out conversion.. more research..lol......
so i got my hands on a nice front cut from a local wrecking yard.....
pulled out the motor, gearbox, wiring loom, ecu, hubs, drive shafts, instrument cluster, suspension, everything my research lead me to beleive id need......
so next step was to turn my attention to the celica..... bring it into the garage and pull out the worthless 5sfe... whaich had given me all sorts of dramas in the year i had it in there.......
so out with the old........dog of a 5sfe
so with engine and gearbox out it was time to see for myself exactly what needed to be done to get the v6 into its new home..
my research has lead me to beleive that all celica mounts would cross over to the camry engine and gearbox......
but this turned out to not be the case......
only one mount crossed over....
so thinking of research again.... i had read that the celica gearbox shares the same bolt pattern as the camry...... so off with the camry box to compare........
(seems as though i have lost these pics.... will find em)
anyhow..... bolt pattern is identicle on both camry and celica gearboxes.... so this meant that the stock celica geabox will bolt upto the v6 engine.....
and that it did... perfectly..... no hassles
now the only issue i had with swapping the gearbox's was, the clutch and the driveshaft bearing carrier.....
clutch was sorted using the camry flywheel, the celica friction plate, and the camry pressure plate..... problem solved, and works perfect.... i had a exedy h/d clutch in the celica so this would only benifit the cross over with the v6....and hold upto the new power of the v6 with no slipping.....
secondly was the driveshaft bearing carrier which had to be modified to bolt to the v6 block..... heres what we came up with.....
so this can now bolt up to the v6 block... and i can still keep celica driveshafts.... which also in turn allows me to keep all celica suspension.... as using camry gearbox would mean changing all suspension and driveshaft to either camry or custom made.....
so with all that sorted it was now time to drop the v6 and celica gearbox into the newhome of a celica engine bay
fits like a charm......
so once all was in and semi bolted down..... it was time to check out all clearences and see what had to be done to completely bolt in......
ONE engine mount.......i repeat..... ONE ENGINE MOUNT was all that was needed to bolt the V6 in to the celica.....
this is what i came up with and is just temparary as another one is being made to replace it......
so now the v6 is completely bolted into its new home it was time to add all the other new goodies......
GT4 56mm twin core alluminium radiator.....
Slotted brake rotors,
then it was reinstall gear selector cables, radiator hoses, and send it off to auto electricians to wire in the camry ecu.....
once auto electrician had wired in the ecu, instument cluster, ran new earthing points and moved battery into the hatch.... it was time to take it to the exhaust shop for custom made exhaust y-pipe merge....
then it was back home to finish off any unfinished items and prepare for start up........
with everything check and rechecked.... it was time for the initial statup......
disconnected coil so engine wouldnt start, and cranked for a little while to get the oil pressure up.......
youtube vid
after teething probs had been sorted it was time to triple check things and fir up again...... and just to hear it.... sounds awesome...
another vid
then once all was good it was time to take it for a spin..... this had been 8 months worth of work as i only got time on weekends to work on the celica...... so i had been waiting for this moment for so long it seems as though it wasnt gonna happen but here we are......BTW ... this was on saturday just gone...... so like 2 days ago......
enjoy the sound and the sights......
removed video from youtube... so put a link in for it from my image shack.... any help to embed this would be much appreciated...thanks
http://img41.imageshack.us/i/video011.mp4
[yt]http://www.youtube.com/watch?v=WM-TJTG8eQs&feature=related[/yt]
so this is where i am currently at with this build.....
once i have completely sorted this conversion out and it is finally driveable as a daily driver.... the next step is to finish the bodykit... of which is going to be all custom made by myself and my mate.....
enjoy all future updates and i hope that this has opened your eyes to other engine swaps possible in 5th and 6th gen celicas......any question hit me up...... only too glad to answer em for ya....
Currently this is where im up to...... and now just sorting out teething problems......
total rough cost of conversion so far is around $3500...... cost of a 3sgte front cut.....$3500..... so i set out to provide another option for celica owner/modifiers in the sense that a 3sgte is NOT the ONLY option when thinking engine swaps......
grant......... thanks for reading....
This post has been edited by fibrewizard: Sep 13, 2009 - 1:42 AM
st184 3vz-fe convesrion complete
st185 AWD 3vzfe turbo conversion in progress
and stock st204 daily....
- fibrewizard   3vz-fe V6, 5th gen.....   Sep 8, 2009 - 11:19 PM
- - Euphoria   hey mate, nice to see you on this forum too, will ...   Sep 9, 2009 - 8:03 AM
- - delusionz   I like it alot, Just wondering if you have the spa...   Sep 9, 2009 - 8:57 AM
|- - fibrewizard   QUOTE (delusionz @ Sep 9, 2009 - 9:5...   Sep 9, 2009 - 9:44 AM
- - njccmd2002   wow, have you dynoed it yet? who made the mounts ...   Sep 9, 2009 - 9:32 AM
|- - fibrewizard   QUOTE (njccmd2002 @ Sep 9, 2009 - 10...   Sep 9, 2009 - 9:50 AM
||- - bdub215   QUOTE (fibrewizard @ Sep 9, 2009 - 10...   Sep 11, 2009 - 7:34 PM
|- - fibrewizard   QUOTE (njccmd2002 @ Sep 9, 2009 - 9...   Nov 6, 2009 - 1:45 AM
|- - bdub215   QUOTE (fibrewizard @ Nov 6, 2009 - 2...   Nov 6, 2009 - 11:24 PM
- - fibrewizard   with permission from my mate in the states...... h...   Sep 10, 2009 - 9:37 PM
- - mmmchocolate   wow that is some nice work! very nice 5th gen...   Sep 10, 2009 - 11:05 PM
- - fibrewizard   this i have ...... i have the 5speed manual trans...   Sep 12, 2009 - 7:04 AM
|- - fibrewizard   QUOTE (fibrewizard @ Sep 12, 2009 - 7...   Nov 6, 2009 - 1:39 AM
- - bdub215   E53=3vz E153=1mz   Sep 12, 2009 - 9:40 PM
- - fibrewizard   sweet.... thanks for the info.... i was told e153...   Sep 12, 2009 - 11:29 PM
- - dabazied   Nice work   Sep 12, 2009 - 11:51 PM
- - Cuts_the_Pilot   welcome fellow australian/ozcelican. any progres...   Sep 13, 2009 - 1:43 AM
- - fibrewizard   just had to buy some bits and peices to help out i...   Sep 13, 2009 - 10:49 AM
- - keison2000   QUOTE (fibrewizard @ Sep 8, 2009 - 11...   Sep 14, 2009 - 10:29 AM
- - fibrewizard   ok..... well starting gearbox conversion this wee...   Sep 20, 2009 - 3:15 AM
- - fibrewizard   thanks   Nov 6, 2009 - 11:59 PM
- - manphibian   nice project just moved to off-topic to tidy up,...   Nov 7, 2009 - 5:49 AM
|- - fibrewizard   QUOTE (manphibian @ Nov 7, 2009 - 6...   Nov 7, 2009 - 6:28 AM
- - richee3   This is an awesome project. Keep up the good work.   Nov 7, 2009 - 11:39 PM
- - fibrewizard   ok so got bored today so thought id do something w...   Jun 22, 2010 - 1:16 AM
|- - Johnnyny   make it legal? you cant have the filter showing or...   Jun 22, 2010 - 4:07 AM
|- - fibrewizard   QUOTE (Johnnyny @ Jun 22, 2010 - 4:0...   Jun 22, 2010 - 4:51 AM
- - fibrewizard   ok well pic is of the versions of thermostat housi...   Jun 23, 2010 - 3:39 AM
- - fibrewizard   gearbox swap is in progress.....just waiting for n...   Jul 22, 2010 - 10:10 AM
- - fibrewizard   new vid after.....E53 camry 5sp conversion   Aug 14, 2010 - 7:41 AM
- - fibrewizard   seen some in the uk, so will be looking for someth...   May 18, 2011 - 3:15 AM
- - Cuts_the_Pilot   We dont take kindly to your type around here. (5th...   May 18, 2011 - 3:34 AM
- - fibrewizard   so extremely close to rego, nothing left to do, ...   May 24, 2011 - 8:23 AM
- - fibrewizard   been so long since i have updated this thread, and...   Jan 13, 2012 - 4:28 AM
|- - GMan   QUOTE (fibrewizard @ Jan 13, 2012 - 4...   Jan 19, 2012 - 12:23 PM
|- - fibrewizard   QUOTE (GMan @ Jan 19, 2012 - 12:23 P...   Jan 19, 2012 - 12:43 PM
- - fibrewizard   well back after a long hiatis, since buying my gt8...   May 4, 2015 - 3:22 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 11:08 AM
