Sep 17, 2009 - 10:24 AM
Enthusiast ![]() ![]() Joined May 28, '09 From Milwaukee, WI Currently Offline Reputation: 0 (0%) |
So the lights on the inside of my celi are not working. The clock, door and over head lights are not working to be exact. I have looked at all the fuses and they seem to be fine. Can any one help me in figuring out the problem that I am having and why these lights are not working on my st....
Sep 17, 2009 - 11:01 AM
The clock isn't working either..? That's what is making this odd.. I would say just check your button in the door to see if that's sticking, as that could be the culprit. Or I have seen several times fuses that looked like they were still good, but were blown. But if your clock isn't working either, I don't know what it could be.. Just try finding a fuse that seems like it could be the problem and replace it anyway. Does your dome light work when you turn it on manually with the switch?
Sep 19, 2009 - 7:33 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
yeah my last car the locks wouldnt work and we thought that the fuse was fine and bought a component for under the hood and it still didnt work so it turned out that the fuse was slightly cracked, it's better to just replace the fuses before taking things apart hoping to find a reason.
| Lo-Fi Version | Time is now: July 30th, 2026 - 4:03 PM |
