> Spark Plugs, Info
post Oct 28, 2003 - 2:59 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
Hey guys, why would someone want to put in DENSO IRIDIUM SPARK PLUGS in their celi.
What difference do they(any performance spark plug) make over the stock ones..
Replies (1 - 9)
post Oct 28, 2003 - 3:28 PM
LatinKraze
Joined Oct 22, '03
I was thinkin the same for Bosch platinum +4 spark plugs.. confused.gif ..whats the big diff??
post Oct 28, 2003 - 3:45 PM
kuya1284
Joined Nov 15, '02
From Corona & Vallejo, CA
QUOTE (kingpreetham @ Oct 28, 2003 - 12:59 PM)
Why? Mostly because people THINK it'll improve their performance...
post Oct 28, 2003 - 3:46 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
I saw minor improvement. But the ones I replaced were also burnt up. wink.gif
post Oct 28, 2003 - 4:12 PM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
QUOTE (LatinKraze @ Oct 28, 2003 - 1:28 PM)
I think my shop put those in when i did the swap and they said the car ran like s**t. I don't know if hey were the wrong ones or what but that pissed me off that autozone gave me the wrong ones.. mad.gif Worst of all i was too late 2 returns them, 30 days had passed and i lost the receipt.
I here good things about the NGK ones tho.
David
post Oct 28, 2003 - 5:47 PM
kingpreetham
Joined Jul 8, '03
From Dallas, TX
QUOTE (ToYCeLi8 @ Oct 28, 2003 - 2:12 PM)
David
What good things....what kinda performance increase do ppl expect, why should spark plugs make a diff...
post Oct 28, 2003 - 6:03 PM
kuya1284
Joined Nov 15, '02
QUOTE (kingpreetham @ Oct 28, 2003 - 3:47 PM)
David
Did you not read my post?
Most people MAY notice SMALL improvements with NEW plugs... because of that reason... they're NEW... this is going on the assumption that your OLD plugs are WORN OUT and NEED TO BE REPLACED...
With a low end motor or a motor that isn't force inducted, there's no point in wasting money in your ignition system. With a high end motor, yes... you'll notice a difference (i.e. Nology and what not).
AGAIN... with your factory motor... you WILL NOT notice any performance...
This post has been edited by kuya1284: Oct 28, 2003 - 6:03 PM
post Nov 2, 2003 - 2:35 PM
97GTinKC
From KC
"AGAIN... with your factory motor... you WILL NOT notice any performance... "
(unless your old parts were in need of replacement anyway, in which case, replacing them with new stock parts would make the same difference.)
post Nov 2, 2003 - 3:39 PM
Pandeo
Joined Mar 18, '03
From Quebec
I have change mine for Bosh 4+.
The only difference I see is about fuel effiency, with a little difference in performance, but only for the first month( this is what I call psychologic HP!). Is same as put only a P-flow. You think you,re faster because your motor do more noise!
..and I read about the computer; when you change anything, the ECu change the tuning to get the most efficient tuning (fuel...) It explain why you reset they ECU you get more power...
So , I think doing only a few thing(CAI + spark plug) is equal to do nothing... Unless you change the throttle body, header, muffler with an ECU upgrade.
post Nov 2, 2003 - 8:38 PM
SpedToe169
From Dallas, Tx
Sorry Pandeo, you're way off. The Bosch +4s don't do a thing. Same deal as the Splitfires of a few years back. The spark will always travel along the path of least resistance, which will usually be the same electrode on the plug. The other 3 do nothing but shroud the flame front and screw up the combustion event.
To my knowledge 6th gens do not have any kind of learning capability built into the ecu. The only things stored in memory are fault codes which do not change how the car runs (unless it ends up in limp mode, very rare). CAIs make dyno proven power. Sparkplugs do not.
Lo-Fi Version Time is now: March 29th, 2026 - 7:25 PM
