Oct 10, 2009 - 11:14 PM
Enthusiast ![]() ![]() ![]() Joined May 10, '07 From Lubbock, Texas Currently Offline Reputation: 2 (100%) |
im wanting light and fast.......what size rims and tires should i go wit....thank you
-------------------- ![]() feedback feedback If I buy or sale please leave me feedback...thanks cheap, quick, reliable, pick two I treat my 6gc better then my own woman |
Oct 11, 2009 - 12:07 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '07 From Washington Currently Offline Reputation: 9 (100%) |
Steelies!!!!
Oct 11, 2009 - 2:10 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
^ truth.
Less rotational mass= best 15x7 would be great. 16x7 will work well too. 17" wheels are pretty heavy. You'll be forking out the big bucks for a lightweight 17" wheel. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Oct 11, 2009 - 2:28 PM
so go wit like 15 wit 205s?
Oct 11, 2009 - 2:42 PM
![]() Enthusiast ![]() Joined Aug 29, '09 From Ottawa, ON, Canada Currently Offline Reputation: 1 (100%) |
20"
Oct 11, 2009 - 8:24 PM
20?....ugh.......im wanting LIGHT.....plus SPEED
Oct 11, 2009 - 11:31 PM
15x7 with a 205/55R-15
Oct 11, 2009 - 11:43 PM
Oct 13, 2009 - 8:05 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
I had 15" (with tyre weighed ~15kg, I dunno if you'd call them light?) Go for 16" good size still and style wise aswell, 15" looked far to small.
Oct 13, 2009 - 9:24 PM
![]() Enthusiast ![]() ![]() Joined Nov 19, '07 From las vegas Currently Offline Reputation: 0 (0%) |
Oct 13, 2009 - 10:02 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
here ya go
http://www.wheelweights.net/ most brand name wheels are there btw, how much does steelies weigh? -------------------- God made man....
Everything else... Made in China ![]() |
Oct 17, 2009 - 4:30 PM
![]() Enthusiast ![]() Joined Apr 16, '09 From Italy Currently Offline Reputation: 3 (100%) |
I think the best option is swap the 7gen celica rims+tires...
the rims are cheap and not that heavy to be oem, the space in the rims is enought to put in it a larger brake system, they are nice for the 6gen and the tire are not to tall, and not to short, good to encrease the corniring forse (with a reaaly good sunspension set up). The tire size is easy to find and cheaper than a 215/40R17 (i learned it at my own) and its tall enought to copy the asphalt, 215/40 R17 tires made my car surely fantastic, and better than before,but a bit too nervous...i'm sure that with a 205/50 R16 set it would be fine and interesting to handle running at high speed...and if u buy 4 spacers too it will look reaaaally good |
Nov 1, 2009 - 3:04 AM
spacers?.......whats that
Nov 1, 2009 - 11:56 PM
some look like big washers. they bring your wheel closer to the guards (to help clear brake calipers and to get the nice flush look), you have to be careful though you should have atleast 6 turns on your wheel nuts.
Nov 2, 2009 - 10:30 PM
Enthusiast ![]() ![]() ![]() Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) |
the best r the enkei rpf1's in 15in are 9.5 lbs each
Nov 4, 2009 - 8:52 AM
Tell me what you look for
To be faster cornering: largest as u can, with not too short (205/50-55R16 or 215/50-45R16 will be fine) and with a low ET (increasing the distance between the centre of the tires is the faster way to increase your cornering speed). But the steering whell will be heavy and return fast in position after the corner To be faster accelerating: the smallest diameter you can Do not reduce too much the distance from the fender, it will increase forces that will make your car harder to drive, and not as safe as before. |
Nov 4, 2009 - 9:46 PM
Enthusiast ![]() Joined Oct 17, '09 From Adelaide, South Australia, Australia Currently Offline Reputation: 0 (0%) |
I'm liking the RPF1 type 2's - http://enkei.com/rpf1type2.html
Nov 5, 2009 - 6:46 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
I'm liking the RPF1 type 2's - http://enkei.com/rpf1type2.html Its too bad the offset is fail. They look good too. -------------------- |
Dec 10, 2009 - 10:30 PM
wow almost forgot i had this post on here.........just learned somewhat bout offset and spacers on another post......so what im really looking for is good show as well as performance......plans: flushed and have performance on street, and at the drags....would like to take it to x races some day....drift is out of questoin since its frnt wheel drive.....drag however i think itll all have to do away with street rims and tires, slicks in frnt small what nots in back
| Lo-Fi Version | Time is now: September 11th, 2026 - 3:13 PM |
