> shave head, to raise compresion
post Oct 28, 2003 - 8:22 PM
95celigt
Joined Jul 9, '03
From Tampa Florida
Has anybody done this or know the effects it will have on a 5f?
post Oct 28, 2003 - 8:50 PM
macavely
Joined Nov 4, '02
never done it but from what i have heard it it reduces weight and allows for better performance... but this was done mostly on iron blocks. don't know if a weakend head could handle the stress..
post Oct 29, 2003 - 11:29 AM
SpedToe169
From Dallas, Tx
It wasn't ever done to save weight. When you're taking about shaving a head, you're talkin about taking 0.040". Thats not even going to save a pound. Its done soely to raise compression.
Its totally doable on our motors and will improve performance. It needs to be done by a good machine shop. Since you'll have the head off anyway, its a really good idea to have a valve job done and put in new seals at the same time. You won't want to take too much off or you'll have to have custom pistons to provide enough clearance for the valves. You're also not going to want to raise the compression much past 10.5:1 if you're going to continue running pump gas. Some combustion chamber designs will allow for higher compression than that on pump gas, but ours likely will not.
Try to find a machine shop that does performance work on imports and preferrably one thats worked with toyotas before. The quality of the shop will make or break the deal.
post Oct 29, 2003 - 11:57 AM
edo17982
Joined Dec 21, '02
From Italy
I've done this work in addiction to valve job and P&P and the result is amazing!!! wink.gif wink.gif
post Oct 29, 2003 - 1:57 PM
Kwanza
Joined Apr 8, '03
From NorCal
Yes, results typically are fairly good... but you'll sacrafice low-end torque for the high-end power... typically a shave job can slightly reduce displacement...
post Oct 29, 2003 - 2:00 PM
95celigt
Joined Jul 9, '03
From Tampa Florida
Thanks for all the info. It sounds like a good idea so I'll do it this month and let you guys know how it went. How much should i shave off of it?
post Oct 29, 2003 - 3:05 PM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE (95celigt @ Oct 29, 2003 - 12:00 PM)
you should call toyota. There is a max amount that you can shave off the head before you will loss the seal. Also you should contact Ferra about making you some oversized ss valves and springs. The valves should be made 1 mm over stock and will better the air flow of the 5sfe head.
For porting your head I would have it gasket matched.
Once you have done all this the only thing left to do to the head is get a set of regrinded cams and you will be set.
-Bryan-
Member of Team 5sfTe
post Oct 29, 2003 - 4:42 PM
FallenHero
Joined Dec 26, '02
From Alabama
I'm sure you could use old school 4age springs. I believe HKS offers a set at a good price.
Jon
post Oct 29, 2003 - 6:50 PM
edo17982
Joined Dec 21, '02
From Italy
QUOTE (FallenHero @ Oct 29, 2003 - 11:42 PM)
Jon
you can us evalve springs of 4AGE?? confused.gif are you sure?? which 4AGE?? Thanks
post Oct 30, 2003 - 12:09 AM
FallenHero
Joined Dec 26, '02
From Alabama
haha, yea, after re-thinking that comment, I am sure I am wrong. BUT, HKS does make valve springs for a 4age. If you are going to custom the head....
I really don't know if they would work or not. I have no clue about the actual measurements of the heads, or what it would take to fit them.
Random thoughts are what you get when you contemplate swapping heads.
You can find them at Nopi.com though if you are curious. Look under old school MR-2 (89 works)
Jon
post Oct 30, 2003 - 9:42 AM
SpedToe169
From Dallas, Tx
Shaving the head does not change displacement at all. Displacement = bore x stroke. Unless you're boring the engine or changing the crank, the displacement stays the same. Changing the deck height (shaving the block) or shaing the head will raise compression and decrease p-v (piston to valve) clearances. Like I said before, just make sure you have the work done by a shop that knows what they're doing.
Lo-Fi Version Time is now: September 3rd, 2026 - 7:49 PM
