Oct 21, 2009 - 1:38 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
So while driving today i crossed a hevily rutted intersection, i guesss from big trucks or whatever. but anyways, After i crossed it i realized that my check oil light had come on. I don't know if this would have any relation to each other but i though i would let you guys know just incase. So I got home and i checked my oil, it was clean and at about the half full level, so I topped it up to the full line and started up the celica again. The check oil light is still on. Does this mean that i could have a bad oil pump? or could it just be an electrical wire that came lose? Anyways, any opinions would be greatly appreciated. Thanks.
-Colin -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Oct 21, 2009 - 1:41 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
u could have low oil pressure
Oct 21, 2009 - 5:42 PM
So what would cause that? and how could i fix it?
Oct 21, 2009 - 6:15 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Does the engine feel heavy or have reduced power? Does your radiator coolant look gunky? Any oil leaks under the car? How do you drive your car? And do you let it warm up before giving it gas?
(Trying to determine whether you have a blown head gasket / cracked head, or an oil leak) If I had an oil light on and there were no visible signs of anything wrong I would do an oil and filter change (see if some crap was clogging the system possibly by sabbotage) and check for error codes here's how -------------------- Mike W
Oct 21, 2009 - 6:18 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
That's a low oil pressure light. You have lost oil pressure for some reason, a line is clogged, pump bad, etc. Oil level usually isn't related (unless you are very low on oil). Typically when that light comes on you should stop the car wherever you are.
-------------------- 1999 Celica GT
Oct 21, 2009 - 7:26 PM
your engine would be making alot of noise by now if the oil pump had failed. could just be a bad oil pressure sending unit.
Oct 21, 2009 - 7:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
there is a little wire on the oil sending unit, its in a little plastic clip, mine broke by itself one day, and it came loose ,the light came on... I plugged it back in and all was well.
-------------------- ◊◊◊ My F/S Thread! ◊◊◊
Oct 22, 2009 - 1:17 AM
there is a little wire on the oil sending unit, its in a little plastic clip, mine broke by itself one day, and it came loose ,the light came on... I plugged it back in and all was well. yea Im pretty sure this is what happened since it came on right after i went over a rough intersection. Where is the oil sending unit located, Im kinda new to cars and just learning things as i go -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Oct 23, 2009 - 2:42 AM
there is a little wire on the oil sending unit, its in a little plastic clip, mine broke by itself one day, and it came loose ,the light came on... I plugged it back in and all was well. yea this is prolly broken or the wire wore off and seperated its located right on front towards the right between the valve cover and head only wire facing forward. -------------------- 94 Celica GT
Nov 2, 2009 - 1:21 PM
So i just realized that i was an idiot and it was the check engine light that went on not the oil light. now im pretty sure thhat its just a sensor that popped off, is there a way to tell which sensor without physically looking for it cause i looked around the enigne bay and exhuast and couldn't find any sensors missing or with torn wires.
Nov 2, 2009 - 9:40 PM
Enthusiast ![]() ![]() Joined Jan 22, '07 From Loveland Currently Offline Reputation: 4 (100%) |
Nov 2, 2009 - 10:24 PM
Alright so it made some sense to me, but where exactly is "Data Link Connector 1" I'm kind new to this. Is it somewhere in the fuse box?
Nov 3, 2009 - 8:33 AM
under hood near the fusebox, says DIAGNOSIS on the lid.
Nov 3, 2009 - 4:34 PM
Nov 5, 2009 - 9:41 AM
Enthusiast ![]() ![]() ![]() Joined Nov 25, '08 From dillsburg pennsylvania united states Currently Offline Reputation: 12 (100%) |
and make sure you go to a place that can read obd1. considering our generation cant work with obd2
-------------------- ![]() those with golf balls golf those with real balls race |
| Lo-Fi Version | Time is now: August 25th, 2026 - 3:35 AM |
