Oct 25, 2009 - 10:25 AM
Enthusiast Joined Oct 25, '09 From RF Currently Offline Reputation: 0 (0%) |
Hey all,
Does anybody knows the valve lift, mm - of the intake camshaft for JDM 3S-GE (3rd gen, from 93 to 12.97)??? It's part-number is 13501-88460, it's non-vvt-i Also will be grateful, if someone also knows the valve lift value for: a) 13501-88560 intake camshaft, was used on JDM 3S-GE after 12.97 (non-vvt-i) b) 13501-79016 intake camshaft, was used on JDM 3S-GE of MR-2 from 1989 to 1991 c) 13501-74041 intake camshaft, was used on JDM 3S-GE of MR-2 from 1991 Thanks! |
Oct 26, 2009 - 12:07 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
Don't know what gen 3S are in B & C but A, I have the valve clearance, dont know if thats what you want?
Valve clearance (Cold): Intake: 0.15 - 0.25mm (0.006 - 0.010 in.) Exhaust: 0.28 - 0.38mm (0.011 - 0.015 in.) -------------------- |
Oct 27, 2009 - 2:11 PM
Rusty,
Thnx That's not the issue we wanted to know... We need valve LIFT, not CLEARANCE... Anyone knows? |
Oct 28, 2009 - 12:11 AM
oh sorry just you had that part number reference, threw me off...
BEAMS is Cam lift (IN/EX) - 10.5mm/9.2mm 3gen 3S-GE 3. gen 3SGE A/T In: 240deg, 8.7mm lift Ex: 240deg, 8.2mm lift 3.gen 3SGE M/T In: 252deg, 9.8mm lift Ex: 240deg, 8.2mm lift The 3S-G heads lift is limited to 10.5mm by the springs after that they become coil bound. Intake flow drops off at about 13mm. -------------------- |
Oct 29, 2009 - 7:03 PM
Rusty,
Bingo Thnx! Topic is over. |
Oct 29, 2009 - 7:32 PM
glad to help.
| Lo-Fi Version | Time is now: August 22nd, 2026 - 9:37 AM |
