Oct 26, 2009 - 7:55 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
So I'm thinking of getting some engine parts i previously had powder coated in a glossy finish stripped and either going with
- Satin paint - Satin powder coating - Black Anodizing Parts in question Hardline Tubes Valve Cover Oil Sub Plate? Various Brakets What is everyone using? And are you having success with regards to durability? This post has been edited by qatar11: Oct 26, 2009 - 8:03 PM -------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
Oct 26, 2009 - 7:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
it depends what parts you are talking about... paint works fine, powder coating holds up a little better and doesn't loose its shine quite as easy, anodizing is overkill... if you're going just black, painting will work just fine...
-------------------- Breaking Axles...
Oct 27, 2009 - 2:41 AM
Enthusiast ![]() ![]() ![]() Joined Jul 9, '08 From California Currently Offline Reputation: 5 (100%) |
Don't bother with annoing anything,
it's SUPER costly, and frankly not worth it in my opinion. Powder coating will definitely last with heat and vibrations, but again, will be pricey. Unless it's a show car, I wouldn't be investing a ton of money into engine bling... -TC -------------------- Live your life for yourself. Don't hold back for anything or anyone.
Oct 27, 2009 - 7:08 AM
Don't bother with annoing anything, it's SUPER costly, and frankly not worth it in my opinion. Powder coating will definitely last with heat and vibrations, but again, will be pricey. Unless it's a show car, I wouldn't be investing a ton of money into engine bling... -TC Not so much bling as..... good engine hygene - I want the engine to look clean and kept when I put it in, and I don't want all the coating to flake off after 1000 miles, assuming of course that the car doesn't burn down to the ground. -------------------- -Mike
Oct 27, 2009 - 4:24 PM
Don't bother with annoing anything, it's SUPER costly, and frankly not worth it in my opinion. Powder coating will definitely last with heat and vibrations, but again, will be pricey. Unless it's a show car, I wouldn't be investing a ton of money into engine bling... -TC Not so much bling as..... good engine hygene - I want the engine to look clean and kept when I put it in, and I don't want all the coating to flake off after 1000 miles, assuming of course that the car doesn't burn down to the ground. I'd just get engine enamel, or high-temp paint and do multiple coats (probably 4-5). It'll last, that stuff is resilient as hell, I got some on my finger nail, and it stayed on there until I cut it off months later... and I wash my hands a lot... -TC -------------------- Live your life for yourself. Don't hold back for anything or anyone.
Oct 27, 2009 - 7:24 PM
to powder coat the block you'd need to totally tear the engine down to a bare block, get it hot tanked and the outside bead blasted, then masked, powdered/baked. you have to take the engine out of the car and totally apart.
Oct 27, 2009 - 8:58 PM
to powder coat the block you'd need to totally tear the engine down to a bare block, get it hot tanked and the outside bead blasted, then masked, powdered/baked. you have to take the engine out of the car and totally apart. I believe that he is doing this to a spare engine that will then be re-installed into the bay. However, I agree, it's a LOT of work... -TC -------------------- Live your life for yourself. Don't hold back for anything or anyone.
Oct 27, 2009 - 9:33 PM
well if thats the case...
QUOTE to powder coat the block you'd need to totally tear the engine down to a bare block, get it hot tanked and the outside bead blasted, then masked, powdered/baked.
| Lo-Fi Version | Time is now: July 9th, 2026 - 12:14 PM |
