Nov 3, 2009 - 8:53 PM
Enthusiast Joined Feb 15, '08 Currently Offline Reputation: 0 (0%) |
update 12/6 Car is running great! Thanks for all the help, added new knock sensor after fixing wastegate. Knock sensor codes gone as well as CEL is off.
Put on new coil pack, which solved the not re-starting when warm issue. Thanks Again for all the help UPDATE- After reading codes I got Codes 52 and 43 Hi, Well, I have "inherited" my sons Celica problems. Some of you may remember the car. His screen name was Turboman23. It's a 95 Celica with 91 or 92 3sgte (not sure which at the moment). I am trying to work on this with car with pre 1970 Chevy knowledge! Anyways on to the history/problem(s): (Sorry for being so long) He blew the engine. He had the bottom end rebuilt. Dr. Tweak redid his wiring harness. Check Engine light stays on. When we read codes (can't remember number, sometime ago) it said Knock sensor. He refused to drive it, has had my car for a year. I want it back. (sorry had to get it out) I took it to a local import shop, they said they could not pull the codes, and that they had to pull them manually(???) and said the wastegate was bad causing knock sensor to "go off". My son said they were wrong. And refused to work on it did not want to "chase parts" in trying to fixi it. He also said he did not know where to get a wastegate for it or if one was available. It has an internal wastgate. So now to the questions: Can a bad wastegate cause knock sensor code? Any idea where to find one? Price? Other reasons/fixes to correct code being thrown so CEL goes off? Can the car be driven?[size="3"][/size] Thanks for any help, Lee This post has been edited by ibanez6: Dec 6, 2009 - 8:53 AM |
ibanez6 Engine Rebuild/Code Problems- NEED HELP! Nov 3, 2009 - 8:53 PM
Bitter pull the code yourself, all you need is a papercli... Nov 3, 2009 - 9:04 PM
ibanez6 QUOTE (Bitter @ Nov 3, 2009 - 10:04 ... Nov 3, 2009 - 10:09 PM
bccentaur3 You can find wastegate actuators on mr2oc or try c... Nov 3, 2009 - 10:45 PM
ibanez6 QUOTE (bccentaur3 @ Nov 3, 2009 - 10... Nov 3, 2009 - 10:58 PM
Bitter once you fix it you should sell it (i'll assum... Nov 3, 2009 - 11:25 PM
ibanez6 QUOTE (Bitter @ Nov 3, 2009 - 11:25 ... Nov 3, 2009 - 11:33 PM
bccentaur3 lol.... get back to us with the code and we can mo... Nov 3, 2009 - 11:44 PM
ibanez6 Guys, I didn't get to the codes tonight loooon... Nov 4, 2009 - 9:29 PM
ibanez6 I got the codes, they are 52 and 43.
I am not sure... Nov 5, 2009 - 8:35 PM
Bitter http://www.extreme-check-engine-light-code...1%20D... Nov 5, 2009 - 9:49 PM
ibanez6 QUOTE (Bitter @ Nov 5, 2009 - 9:49 P... Nov 5, 2009 - 10:38 PM
bccentaur3 Remove the hoses from the wastegate actuator to th... Nov 6, 2009 - 12:04 AM
ibanez6 Bitter and Bcccentaur,
Thanks for the help. I ran ... Nov 6, 2009 - 8:18 PM
Bitter connect the boost controller up correctly as the i... Nov 6, 2009 - 10:08 PM
ibanez6 QUOTE (Bitter @ Nov 6, 2009 - 10:08 ... Nov 6, 2009 - 11:05 PM
Bitter because judging by his car (and how its put togeth... Nov 7, 2009 - 1:13 AM
ibanez6 UPDATE- Been down from shoulder surgery, My other ... Nov 25, 2009 - 1:20 PM
Mstoochn in other words, if u run it then try and start it ... Nov 25, 2009 - 3:03 PM
ibanez6 QUOTE (Mstoochn @ Nov 25, 2009 - 4:0... Nov 25, 2009 - 3:10 PM
Mstoochn same problem i have/had, My fix is turn the key to... Nov 25, 2009 - 3:53 PM
ibanez6 QUOTE (Mstoochn @ Nov 25, 2009 - 4:5... Nov 25, 2009 - 7:30 PM
ibanez6 update Car is running great! Thanks for all th... Dec 6, 2009 - 8:51 AM
Bitter so is it pretty fun to drive? i bet he wants it ba... Dec 6, 2009 - 12:01 PM
turboman23 QUOTE (Bitter @ Dec 6, 2009 - 1:01 P... Dec 6, 2009 - 3:26 PM
Bitter QUOTE (turboman23 @ Dec 6, 2009 - 3... Dec 6, 2009 - 3:49 PM
turboman23 QUOTE (Bitter @ Dec 6, 2009 - 3:49 P... Dec 6, 2009 - 4:44 PM
Bitter QUOTE (turboman23 @ Dec 6, 2009 - 4... Dec 6, 2009 - 8:10 PM
turboman23 QUOTE (Bitter @ Dec 6, 2009 - 8:10 P... Dec 6, 2009 - 10:47 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 8:07 AM |
