Nov 4, 2009 - 11:39 PM
Enthusiast Joined May 13, '03 From FT Lauderdale FL Currently Offline Reputation: 0 (0%) |
I have a 1994 Toyota Celica Coupe that im testing the waters and taking offers this has been my baby for pass 12 years.
I will not part out since I know eveybody will be asking for something they want from it. The car needs body work so Im selling it as is for right now. Im not in any hurry to sell and might even change my mind and fix the body and repaint it or even get a new body 99gt lol but who knows when that would happen. I've been so busy working and have no time to play with my baby no more Ok so know for the good stuff what I have Toyota Celica 1994 Coupe 2nd gen 3SGTE title salvage tilte Miles body 104k engine miles 1144 I know I need drive it more lol 3SGTE mods built up I have the dyno sheet 330whp 312tq at 18psi stage 3 clutch master spearco front mount intercooler Blitz turbo timer Blitz super sound blow off valve Apexi avc-r boost controller SDS standalone engine management 3sgte block Hot tank,Mag, Bore JE Forged pistons 9.0:1 compression Eagle "H" beam Connecting Rods NEW OEM Crankshaft New OEM Timing Belt New OEM Timing belt Idler New OEM Water pump 3sgte Head work Street port clean, blast and pressure test 3 angle racing valve job removed place vavles surface head adjust shims pain in the ass! Ferrea 1mm over sized valves Ferra valve springs and retainers HKS Head Gasket 1.2mm ARP High Performace head bolts transmission 3sge soon still need drop in 3sgte transmission E-153 turbo ct-26 upgraded to 60-1 pulls really nice Fuel st205 stock 550 injectors fuel pressure regulator tranny gt tranny axles stage 1 gator axles Suspension kyb struts Camber kit Exterior 4 pc erebuni body kit paint job competition yellow 18inch rims GTX Raptors Also so throw in the a spare 3sgte block and head that I have siting in the garage. I have the 3sge tranny in the car now but the e-153 mr2 tranny is siting in my garage too. What i really wanted to do was get this bad boy in a 1999 gt body and convert it awd that would be nasty but I been looking around and no luck. The motor put down 330whp at around 18 psi that on the ct26 turbo that has been upgrade and i was still using the internal wastegate so it wouldn't open anymore so you could image with external waste gate or been a bigger turbo easly over 400hp motor. anyways you can reach me at please email me if you have any questions. Mikecmia23@hotmail.com you can try me at AIM too mikec954@aol.com I have pictures of the build and Ill see if I can get a video up and share it Thanks Mike |
| Lo-Fi Version | Time is now: August 27th, 2026 - 11:45 PM |
