Nov 5, 2009 - 8:32 PM
Enthusiast ![]() Joined Apr 28, '07 From Venezuela Currently Offline Reputation: 0 (0%) |
Hi friends! i have a little problem with my axles!... Well the thing its when i bougth the swap the came with the gearbox! but when i remove the axles from de new engine i see that they are totally diferent from my old ones!... Anyones knows from what gearbox, car, etc are this axles??? if i buy a new pair they will fit into my celi?
![]() (The left one its from the old 3sfe engine, the cut one its the new axle |
Nov 5, 2009 - 9:51 PM
will your old inner joint go into the other axles cup? if it fits correctly then there ya go, custom axles! otherwise you need to tell us what trans you bought or what 'swap' you bought.
Nov 6, 2009 - 5:11 AM
im shure that the cup dont fit because the other one is much bigger. i bought a 4gen 3sgte with fwd transmission but they dont specify the type :S
Nov 25, 2009 - 5:26 PM
Ok, ill search around the web and i think that the gearbox that comes with the swap its an C52 gearbox. The axles cup are totally direfents, there are bigger!.. I will like to put a nice axles setup, like oem toyota axles that fits there nicely, any ideas?
The othe solution its to chage to my old gearbox! but im shure she cant old the power There is a pic from a gearbox like mine ![]() Help please! Thx |
Nov 25, 2009 - 5:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
wait........the c52 is from an A series toyota engine, why is it in a GT???
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Nov 25, 2009 - 9:12 PM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
Front axles:
PN# 43410 is your passanger side PN# 43420 is your driver side This post has been edited by Mstoochn: Nov 25, 2009 - 9:12 PM |
Nov 26, 2009 - 6:32 PM
nice info Mstoochn
Nov 26, 2009 - 9:04 PM
they are St215 caldina axles, which have the same wheel base depth. they are the only axle i no of that you can use with a c52 trans in a celica
Dec 6, 2009 - 3:40 PM
so i must order St215 axles
Dec 6, 2009 - 4:23 PM
so i must order St215 axles yes, the FWD axles are available in northamerica, although not THAT easy to find. I belive there is also an alternative using a mix of inner and outers from the mr2 and st202 inners. I will look into it for you. This post has been edited by Mstoochn: Dec 6, 2009 - 4:24 PM |
Dec 7, 2009 - 5:10 AM
iŽll find around the web too. I think that the st202 dont work because the other axle its bigger and i need the rear mount for the passenger side axle
![]() ![]() Other thing its that im not pretty shure that my trans its a c52, but i read in some other forums that the c52 trans have a black cover (5th gear cover). Any other toyota trans with this black cover? :S. Thanks a lot for your help Mstoochn! |
Dec 7, 2009 - 8:02 PM
iŽll find around the web too. I think that the st202 dont work because the other axle its bigger and i need the rear mount for the passenger side axle ![]() ![]() Other thing its that im not pretty shure that my trans its a c52, but i read in some other forums that the c52 trans have a black cover (5th gear cover). Any other toyota trans with this black cover? :S. Thanks a lot for your help Mstoochn! locate the starter, look adjcent to the start and there will be a Serial Num for the tranny. 8E4 or 8E5 will be the first three digits of a C52 trans. if this came from a st215 calinda is would have to be a c52 |
Dec 8, 2009 - 5:11 PM
i dont see any serial number around there
Dec 8, 2009 - 6:27 PM
Dec 9, 2009 - 5:34 AM
Dec 11, 2009 - 6:04 PM
any idea where i can get that stuff? .... the two axles and the middle mount
Dec 11, 2009 - 7:33 PM
yea thats from a fwd calinda... wow
u may need to go custom axles. or use the calinda half shafts with st185 or st204 axles with an axle spacer |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 10:10 PM |
