Nov 7, 2009 - 11:31 AM
Enthusiast ![]() ![]() ![]() Joined Jan 10, '09 From Burtonsville, Maryland Currently Offline Reputation: 1 (100%) |
Hey guys its your favorite seller again
I have now an Audiobahn A4002V amp thats good for up 800 watts. * RMS Power Output: o 100 watts x 2 chan. @ 4 ohms o 200 watts x 2 chan. @ 2 ohms o 400 watts x 1 chan. @ 4 ohms Bridged * Max Power Output: 800 watts @ 2 ohms * Class A/B MOSFET Circuitry * PWM MOSFET Power Supply * Non-regulated Power Supply * Semi-double Sided Glass Epoxy Circuit Board * 4-way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset * Air Induction Cooling Fan * Soft Start Circuitry * Cobalt Blue Illumination * Speaker level (high-level) inputs * Preamp outputs * Nickel-Plated Block Terminals * Bass Boost Control: On/Off (0 or +18dB) * Variable Low-Pass Crossover: 50-120Hz * Variable High-Pass Crossover: 50-750Hz * Signal-to-Noise Ratio: 100dB * Frequency Response: 10Hz-40kHz * Variable Subsonic Filter: 20-50Hz * THD: 0.02% * Input Sensitivity: 200mV-8V * Dimensions: 8-3/8"L x 11-1/16"W x 2-1/8"H Reason im selling this is because I made an error thinking I had to replace my old one.. turned out that it was just my RCA's that were bad.. so yea I have this one just sitting around when im sure someone else could use it. This thing can make basically any subwoofer thump real good.. ive been using 2 12 inch Dual subs.. not the best subs by any means but it sounds great because of the audiobahn amp I have. ![]() ![]() So yea $90 bucks + shipping for this.. I paid $130 for it. Thanks for looking This post has been edited by SlvrCelica09: Dec 19, 2009 - 1:22 PM -------------------- THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma.. 6gc.net's outlaw vigilante because im a LEADER not a follower. ![]() |
SlvrCelica09 FS: Audiobahn A4002V amp Nov 7, 2009 - 11:31 AM
SlvrCelica09 bumpy Nov 9, 2009 - 11:16 AM
dustin15brown Time out:
Why is your sig so ridiculous and retard... Nov 9, 2009 - 10:15 PM
SlvrCelica09 QUOTE (dustin15brown @ Nov 9, 2009 - 10... Nov 10, 2009 - 12:15 PM
SlvrCelica09 bumpy Nov 11, 2009 - 10:08 AM
SlvrCelica09 bumppp Nov 12, 2009 - 8:19 PM
SlvrCelica09 bumpy Nov 14, 2009 - 7:06 PM
SlvrCelica09 bumpp Nov 16, 2009 - 11:23 AM
Joe_1985 is it 800w max or 800rms?
i may be interested dep... Nov 16, 2009 - 2:04 PM
SlvrCelica09 QUOTE (Joe_1985 @ Nov 16, 2009 - 2:0... Nov 16, 2009 - 4:00 PM
SlvrCelica09 bump Nov 17, 2009 - 2:45 PM
SlvrCelica09 bumpy Nov 19, 2009 - 11:07 AM
SlvrCelica09 bumpz Nov 21, 2009 - 12:26 AM
CelicaGTSboy23 Is the amp a class a/b or is it a d-class? Nov 21, 2009 - 8:44 AM
SlvrCelica09 QUOTE (CelicaGTSboy23 @ Nov 21, 2009 - 8... Nov 21, 2009 - 4:05 PM
SlvrCelica09 bumpy Nov 23, 2009 - 11:40 PM
SlvrCelica09 sounds like bump 2 meeeeee Nov 26, 2009 - 2:31 PM
SlvrCelica09 bumpz Nov 29, 2009 - 11:33 AM
SlvrCelica09 bumpz Dec 1, 2009 - 6:16 PM
SwissFerdi Might be interested in this...I call dibs. Dec 1, 2009 - 9:50 PM
SlvrCelica09 no problem.. let me know if you have any questions... Dec 2, 2009 - 1:19 PM
SwissFerdi Yes. How long did you use it, did you use it hard,... Dec 2, 2009 - 7:02 PM
SlvrCelica09 I used it ONE time, its basically like new.. those... Dec 2, 2009 - 9:21 PM
SlvrCelica09 bumpy Dec 4, 2009 - 8:32 PM
SlvrCelica09 bump Dec 9, 2009 - 11:04 PM
SlvrCelica09 sounds like bump to meeee Dec 12, 2009 - 11:37 AM
SlvrCelica09 bumpz... Christmas deal....
buy it on or before t... Dec 19, 2009 - 1:21 PM![]() ![]() |
| Lo-Fi Version | Time is now: May 25th, 2026 - 8:46 PM |
