> bad wastegate?, Tial 38mm external
post Nov 20, 2009 - 11:07 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
hey all, i have been having problems with the car going into boost and have been getting horrible throttle response.
i figured it was a leak so i checked all my ic/piping and the POS knock off Blow off valve i had (replaced with a tial Q)
after i did that, i drove it still bad response, so unless i missed a leak somewhere (i doubt) im automatically thinking wastegate. (i ruled out it being vaccum line placement because before i changed BOV's i could still feel a little boost albeit not much)
before i go taking apart the wastegate to inspect diaphram/spring i want to be sure so i will tell you what i hear when accellerating: when on WOT i hear a rush of air (similar to what it sounds like when i used to hit boost and it exits the dump tube when it was functioning proper)
whats weird is that my boost guauge will read 20psi if i hold it, but wont hold steady and will flutter when cruising on highway.
after researching im thinking wastegate, although i hear tial's reliability is near bulletproof. but ive also read other possiblities. I just want 6gc community opinion on this
This post has been edited by easternpiro1: Nov 20, 2009 - 11:08 AM
- easternpiro1   bad wastegate?   Nov 20, 2009 - 11:07 AM
- - easternpiro1   anyone?   Nov 21, 2009 - 2:54 PM
- - presure2   Did you chech to see if thhe diaphram is stuck ope...   Nov 21, 2009 - 3:22 PM
- - easternpiro1   QUOTE (presure2 @ Nov 21, 2009 - 3:2...   Nov 21, 2009 - 4:32 PM
Lo-Fi Version Time is now: May 24th, 2026 - 9:05 PM
