> 3s-ge Beams or 3s-gte?, tell me what u think!
post Oct 31, 2003 - 7:12 PM
SoundSlut_dotcom
Joined Feb 16, '03
after this winter im gunna have about 3g's to play with for my car.. I was thinking of going with the redtop beams engine..simply for the fact not many have done it. and i heard its a pretty strong reliable engine, but i kno the 3sgte produces more hp.. which would be harder if u know? and which would u suggest for me thanx..
Replies (1 - 15)
post Oct 31, 2003 - 8:24 PM
If you want something that's more unique, I'd go with the BEAMS 3S-GE, but I think you'll spend much more on the engine, because it's fairly new and not many cars were available with that engine. As far as installation goes, I'd guess that it'd be fairly similar mechanically to a 3S-GTE swap, but the wiring is probably more complex than the wiring for a ST185 3S-GTE, becuase the engine is newer and probably uses more electronics. If you get the BEAMS 3S-GE from a ST202 Celica or a Curren, you'll be able to use that tranny and not have to buy another tranny, like you would if you went with a 3S-GTE.
Either way it'll be sweet, but I think the BEAMS 3S-GE will be more expensive, and it doesn't have the torque all around the powerband like the 3S-GTE does.
post Nov 2, 2003 - 9:53 PM
SoundSlut_dotcom
Joined Feb 16, '03
biggrin.gif thanks coomer
post Nov 2, 2003 - 11:27 PM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
If you want to be unique and powerful, you could always do the V6 swap. Though it would be one of the most difficult. To my knowledge, no one has done it in a sixth gen, just a fifth.
For the cash though the beams is for show and not a good bang for the buck, the power only comes through high revs.
Let us know what you end up doing.
post Nov 3, 2003 - 6:13 PM
Rivo
Joined Apr 28, '03
The power does not go through the high revs. The BEAMS VVT-i is not what everybody thinks of. There was a deep discussion of this on celica.net that was very explanatory. The BEAMS revs to 7400, only 400 above a 3sgte. The BEAMS can very solidly be placed at 240 hp with a good exhaust and an EMS, not so bad in a car that weighs 2590 lbs. I would take 240 N/A over 255 Turbo anyday, but that's just IMO and why I chose to go with the BEAMS.
Edit: http://celica.net/cgi-bin/ultimatebb.cgi?u...29;t=004695;p=1
Scroll near the bottom
This post has been edited by Rivo: Nov 3, 2003 - 6:13 PM
post Nov 3, 2003 - 7:08 PM
GeEkBoY
Joined May 17, '03
guess I should have been more specific. The beams does not have high torque figures and the peak torque is high at 6000 RPM with 159 ft-lbs.
A 2nd gen JDM 3sgte has more torque and is available much lower in the revs: 225 ft-lbs @ 3200 RPM. Gives you a much more streetable engine. Even though it only has 15 more horses, this would give you a much faster car than a beams, assuming you can get traction. Don't get me wrong, I would blow my load every time I opened the hood if I had a BEAMS under there, but I don't believe it is worth the cash.
post Nov 3, 2003 - 7:46 PM
Rivo
Joined Apr 28, '03
QUOTE (GeEkBoY @ Nov 3, 2003 - 5:08 PM)
225 ft-lbs @ 3200 RPM. Gives you a much more streetable engine...assuming you can get traction.
That's exactly my point, assuming you can get the traction. I have a car that's kickass in the twisties with the 5sfe. With 100 hp more, and w/o the traction worries of the GTE, I'll be flying.
post Nov 4, 2003 - 10:03 AM
SoundSlut_dotcom
Joined Feb 16, '03
post Nov 4, 2003 - 1:15 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Rivo @ Nov 3, 2003 - 3:13 PM)
hrm,
good exhaust and EMS on 3sgte would get easily over 300hp(@ crank)
i personally, would not like to have a beams 3sge. the torque is too high in the power band and it will never be a high amount unless you remove the VVTI and put in some custom cams, but then it wouldnt be a BEAMS engine anymore would it?
i agree on the v6 swap. get that engine with the TRD SC and it will fly. boat loads of torque!
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Nov 4, 2003 - 4:08 PM
Rivo
Joined Apr 28, '03
and boat loads of non traction. For strip purposes I would get a 3sgte with the MR2 tranny /w LSD. Only time I would want that much power/torque would be if I had an actual all-trac, with the AWD to handle it. For twisties purposes, I would take a 3rd gen 3sge and get the SC kit from JapanSpeed in the UK, not to mention the JUN stroker and other goodies. Massive HP and Torque figures aren't always what's going to get you what you want to do. A time and application for everything.
And no it wouldn't. New non-vvti cams = no more vvti. Just a pretty Head cover.
post Nov 4, 2003 - 8:53 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (Rivo @ Nov 4, 2003 - 1:08 PM)
it is pretty, isn't it?
post Nov 5, 2003 - 12:03 AM
snadman
From Minnesota, USA
Not just pretty...the head cover gives iut all its power...didn't ypou know that if you have a pretty valve cover you get like 70hp more? Intake adds like 30..exhuast like 50...man...thats like 500 bucks for 150hp!!!!Stick ers add hp too! So i covered my car in bumper stickers...yeah I got a 10 second car baby!
just kidding baout all that...honestly the valve cover is pretty lol
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Nov 6, 2003 - 9:19 AM
maikl
Joined Mar 3, '03
From cyprus
QUOTE (Rivo @ Nov 3, 2003 - 4:13 PM)
i have an beams and i am very pleased i eat type-r and gsr for breakfats, but what is an ems????
post Nov 6, 2003 - 2:11 PM
Rivo
Joined Apr 28, '03
EMS = Engine Management System. A standalone unit, such as the Haltech E6K or E11, can completely control everypart of your engine, and can be tuned to the specs you want. By using a dynometer and this software provided with the unit, you can take full advantage of the mods to your car, and tune the fuel/air mixture for peak performance throughout the power band. Can easily add 30hp just through tuning.
post Nov 7, 2003 - 4:57 AM
maikl
Joined Mar 3, '03
From cyprus
QUOTE (Rivo @ Nov 6, 2003 - 12:11 PM)
do you know any ems that will fit ny car? i looked but found nothing
post Nov 10, 2003 - 5:38 PM
Rivo
Joined Apr 28, '03
Of course, any EMS will fit ANY car. That's the whole point, it's a stand alone ECU that's non-car specific.
http://www.haltech.com
That's what I have
Lo-Fi Version Time is now: September 3rd, 2026 - 10:05 PM
