> No spark
post Nov 21, 2009 - 2:34 PM
Gtguy22
Joined Apr 6, '09
From Mass
frown.gif so yesterday i got the car running, leak free! I was really excited about it, the engine was still revving up and down, but i took it for a ride anyway. It stalled out on me and i ended up having to push it for about a mile. Which sucked, anyway looking at it today, it wont start again, almost possitive im getting fuel, but im not getting any spark, i changed the plugs, wires and cap and that fixed the problem for about 20 minutes yesterday. now im back where i started. Any ideas?
post Nov 21, 2009 - 3:21 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
So first thing, you had some idle hunting and the problem never got resolved before you drove? And you verified your not getting spark (by pulling the wire from the ignition coil, 1/2 inch from ground, crank...)? Im kinda leaning to the air part...for now. Are you pulling any codes?
This post has been edited by Spider77: Nov 21, 2009 - 3:42 PM
post Nov 21, 2009 - 4:27 PM
Gtguy22
Joined Apr 6, '09
From Mass
well finally got spark, i guess the distributer on the new engine was junk. Now i have to set the timing, does anyone know what the timing advancement needs to be at
post Nov 21, 2009 - 4:40 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
10 btdc. But since you have a 94, you should be able to advance the timing if you so chose.
post Nov 21, 2009 - 6:40 PM
Gtguy22
Joined Apr 6, '09
From Mass
set as i choose? i dont follow
post Nov 21, 2009 - 8:18 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Well, you can drop it below 10, but that'll retard your timing. By advancing it you can gain a little more power, but need to run a higher grade of fuel. Considering that you have a 94, as it seems you are unable to advance timing on 96+
This post has been edited by Spider77: Nov 21, 2009 - 8:19 PM
Lo-Fi Version Time is now: August 31st, 2026 - 9:34 AM
