Nov 28, 2009 - 2:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
It happened... im a bit disgusted right now. hole in oil pan, smelled coolant. going to check it out tomorrow... get it on a lift and have a look-see.
This post has been edited by easternpiro1: Feb 18, 2010 - 9:39 PM -------------------- |
Nov 28, 2009 - 2:57 AM
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
Nov 28, 2009 - 10:58 AM
Enthusiast ![]() ![]() Joined Jan 22, '07 From Loveland Currently Offline Reputation: 4 (100%) |
Damn. Sounds like you mighta did a good number on it!
Nov 28, 2009 - 12:52 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 27, '09 From Columbus, Ohio Currently Offline Reputation: 3 (100%) |
Judging by what happened to your first Celica in your signature, you haven't had the best of luck
Nov 28, 2009 - 1:14 PM
Enthusiast ![]() Joined Jan 28, '07 From Québec, Canada Currently Offline Reputation: 1 (100%) |
Damn man, I'm really sorry to hear this... Good luck!
Nov 28, 2009 - 4:50 PM
that sucks man... hope you can fix it
Nov 28, 2009 - 6:04 PM
noooooo!!!!!! BOOOO!!! im so sorry man. i know how you feel.
Nov 28, 2009 - 6:13 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 18, '07 From Bergen county NJ Currently Offline Reputation: 24 (100%) |
I am so sorry that stinks
Nov 28, 2009 - 6:56 PM
thanks guys... im about ready to thow the towel in... im not sure if any other gen block will go with it due to the crank position sensor. my boy says if i get somethin like an AEM it wouldnt matter. but idk...
talked to tweak he said that a 5sfe block might work, but i gotta take the motor out and see for sure what happened... i belive the rod went thru the oil pan -------------------- |
Nov 28, 2009 - 7:13 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
-------------------- ◊◊◊ My F/S Thread! ◊◊◊
Nov 29, 2009 - 7:11 PM
Toyota owns you bro.... Sorry to hear
Nov 30, 2009 - 4:30 AM
Ive seen that happen when a guy took his hilux through heavy almost deep water, car died and he kept cranking his car up til it snapped and shot through the side of the block and made a big nasty hole.
Nov 30, 2009 - 8:21 PM
i was so disgusted i didnt want to tell details as to what happened but i just spilled my guts on mr2oc so its only fair to let my 6gc brothers in on it (*sigh* lagos is going to see this... im embarrassed
ok i'll start from the beginning: first of all i got the swap done ORIGNIALLY by dr tweak (phoenix tuning) he did the job RIGHT. unfortunately i got into a head on accident and messed up the hatch that the 4th gen was orignially in. i found a replacement celica (94coupe ninja turtle#2) and was referred by tweak to Southern car customs to get it done again (since he was unavailable) SCC half assed me for months, requring me to go back and forth from charlotte to savannah several times(bad exhaust manifiold setup ) and the car hasnt been right since. they didnt street tune just a base tune to get me around. fast forward to more recent: I had been noticing that i would go into boost cut (fuel cut) when the car was at a certain point in boost and rpm range it threw some engine codes including knock sensor, 02 sensor and a couple others. when i would try to go into boost later i noticed my guage would read boost, but i would get sluggish response i assumed bad cat, and maybe stuck wastegate (tial 38mm) i fixed the problems with the codes but the car woudl still not boost properly (still sluggish not sure why still) first i decide to fix the cat (since i was sure it was clogged) in doing this welding is required, and i dont know how to so i had a reputable local shop do it. I let the guy drive the car on the way back to the shop and he hit boost and the check engine light came on again after boost cut (didnt surprise me) i again noticed the guage was reading WAAY over a boost level i was comfortable with so i say to him chill for a bit. we get on the highway to return to the shop and he got on it again, and by the time i told him to get off the gas (boost gauge reading 20psi) i hear a pop, car shuts off and i smell coolant and see oil leaking from under the car. it seems that the rod went thru the oil pan but im going investigate fully on thursday (take motor out and diagnose where i should go from there) is that bad luck or what lol, like my friend that owns the shop says: damn matt u cant have nothin nice! lol ![]() but hopefully i can find a decent block at a good price and get the workin again and put in my OWN elbow grease (thanks lagos) getting it back in with some help from dr tweak who's been helping me since he did the swap in oct 06. he has pics of "ninja turtle #1 and the damage on his site www.phoenixtuning.com under completed swaps its the green and black celica. -------------------- |
Dec 1, 2009 - 9:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
Danggg,that guy is totally at fault,is he gonna fork out ANYTHING?Sad to hear but im glad ur sticking with it
-------------------- BANNED. for life, you moron.
Dec 1, 2009 - 10:59 PM
You'll be back to boosting in no time!
Dec 1, 2009 - 11:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
that guy has got to have insurance and he should cover it, he is at fault and friend or not when you tell someone not to get on it and they do anyways they are at fault, personally i would of pulled the guy out of the car and beat the living hell out of him, but hey thats just me
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Dec 1, 2009 - 11:37 PM
Sucks that your car got blow'd up
I thought I had bad luck with Celicas and deer. Sounds like you've got much, much worse luck. I hope to see Ninja Turtle Deuce back on the road again soon! -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Jan 4, 2010 - 9:44 PM
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() HEAD NOT DAMAGED!! WOOOT!!! ![]() ![]() Pic from bottom side... doesent that rod look awesome?!? and yes... those are bits of piston... ![]() ![]() took these pictures a month ago, just got around to posting them... right now im looking for a block, 3rd gen or preferably 4th gen... hopefully i'll get back on the road soon! I'll tell you what though... i really enjoyed taking it out actually.... its going to be a BEEYOTCH putting it back in -------------------- |
Jan 4, 2010 - 9:47 PM
![]() *redneck voice* Well there's your problem That is brutal!!!Hope you get it up and running again soon!! This post has been edited by CelicaST_CALI: Jan 4, 2010 - 9:50 PM -------------------- BANNED. for life, you moron.
Jan 4, 2010 - 10:33 PM
holy molly, thats bad!!!
just patch it over. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
| Lo-Fi Version | Time is now: August 25th, 2026 - 9:31 PM |
