Dec 2, 2009 - 6:47 PM
Enthusiast ![]() ![]() Joined Sep 12, '05 From Who says you can't circle race a celica? Currently Offline Reputation: 5 (100%) |
OK really the rear defogger relay...where the hell is it? Is it in the panel containing the fuse for the defogger? If so which one is it?
-------------------- 94 GT Liftback
86 GTS Coupe (Racecar) #99 Crew Chief |
Dec 2, 2009 - 10:31 PM
Enthusiast ![]() ![]() Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) |
It could be behind under the dash behind the fuse panel inside the car. That's where a couple other relays are, like the one for the fog lights on 96+ cars.
Dec 3, 2009 - 12:38 PM
Yeah I got a bad feeling I am gonna have to test each relay and find it. Thanks.
Dec 4, 2009 - 10:52 AM
Enthusiast Joined Aug 29, '09 From Ohio Currently Offline Reputation: 7 (100%) |
Dec 4, 2009 - 12:46 PM
Enthusiast ![]() ![]() Joined Mar 23, '08 From Denmark Currently Offline Reputation: 10 (100%) |
Yeah I got a bad feeling I am gonna have to test each relay and find it. Thanks. Have u found it? I think mine needs to be changed to -------------------- [font=CELICA FOREVER][/font]
Dec 4, 2009 - 8:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
When I push the rear defrost button on my celi, I hear the relay click from the L (driverside) kick panel/fuse area. Yeah I got a bad feeling I am gonna have to test each relay and find it. Thanks. x2...i somtimes like to play a song hahha -------------------- BANNED. for life, you moron.
Dec 4, 2009 - 10:21 PM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
it is in the drivers side kickpanel. According to my schematic though it is not inside a junction/relay block. The connector for the wires is but I believe the relay itself is not if I'm reading it correctly
-------------------- ST205 Crew represent
![]() Challenge Accepted |
Dec 13, 2009 - 2:07 PM
When I was wireing my alarm, I took the fuse block off on the driverside. There were relays on the backside of the fuse block. It may be one of those.
it is in the drivers side kickpanel. According to my schematic though it is not inside a junction/relay block. The connector for the wires is but I believe the relay itself is not if I'm reading it correctly |
Dec 27, 2009 - 2:02 AM
Enthusiast ![]() ![]() Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
if your defog is not working check these fuses first than the defogger relay.
HTR FUSE DEF FUSE and than your defogger relay. They are all located under your dash (instrument panel junction block) From what I remember correctly is that there is 3 relay that looks exactly the same. They are all black... which is kind of stupid because in the manual they don't say which is which. Guess and check for continuity all, I guess? Hope that helps. -------------------- ![]() |
| Lo-Fi Version | Time is now: September 15th, 2026 - 12:24 PM |
