Dec 5, 2009 - 6:39 PM
Enthusiast ![]() ![]() ![]() Joined Nov 27, '09 From Canada Currently Offline Reputation: 4 (100%) |
Ok it wasn't bothering me before but now it is since w ter time is coming and I'm going to be needing fluid sprayed onto my windshield. So the problem is the rear mont sprays water, but for some reason the front isn't. Are they using seperate pumps? And if they are, does anyone happen to know how I can get to the front mount washer fluid pump to replace it?
Goonter Washer fluid pump Dec 5, 2009 - 6:39 PM
pyeatts It's a single reversable motor. One direction... Dec 5, 2009 - 7:30 PM
Goonter Ok thanks a bunch for the info pye . I'll try ... Dec 5, 2009 - 7:33 PM
Cutrara replace with genuine toyota part, dont use cheap u... Dec 5, 2009 - 7:55 PM
pyeatts Cutrara Is exactly right! Aftermarket isn... Dec 7, 2009 - 4:34 PM
IBTINTN I am going to put this out there because it happen... Dec 7, 2009 - 5:15 PM
solidxsnake QUOTE (IBTINTN @ Dec 7, 2009 - 5:15 ... Dec 8, 2009 - 12:11 AM
pyeatts It can run in one direction and not the other. Th... Dec 9, 2009 - 12:30 AM
Goonter ok so i tested what you said pyeatts.. apparently ... Dec 9, 2009 - 2:17 AM
pyeatts washer pump 85330-06020 Dec 9, 2009 - 9:48 AM
DKGT4 Is the washer pump and the wiper motors the same o... Nov 24, 2015 - 2:12 PM
DKGT4 Still looking for an answer to my question above..... Dec 14, 2015 - 12:33 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 27th, 2026 - 1:15 AM |
