Dec 5, 2009 - 8:00 PM
Enthusiast ![]() Joined Apr 6, '09 From Mass Currently Offline Reputation: 0 (0%) |
This is actually a repost, i figured maybe someone in this section might also have an answer, seeing as it is an electrical issue. Ok so some of you know, ive been having problems getting my 5sfe to start. Thanks to all of you, i was able to find the source of the problem. Im just not sure how to fix it. Heres the deal, there are two connector plugs off of my distributor. one has four wires, the other has two. It looks like the two wire connector puts power into the coil. One wire for power, one wire for ground (of course). With a test light on the power wire, i will have power for a few minutes, and then it cuts out. i tried getting into the wire harness alittle bit, hoping the ground wire and power wire were somehow touching each other somewhere under the throttle body, but the problem is still there. Its very weird. Literally one minute my test light will read power off of that little wire, and the next minute its gone. When that wire stays hot, the engine starts. So this is the root of the problem. First off, does anyone know where the other end of those two wires is? Seems like if they are touching somewhere, i could just run two wires from where they start up to the distributor. What else could be causing this"? and what would i have to do to fix it?
Gtguy22 Wiring trouble Dec 5, 2009 - 8:00 PM
Davinci on 92 and 93, the white blue wire goes to the ign... Dec 17, 2009 - 2:29 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 8:43 PM |
