Dec 7, 2009 - 5:41 AM
Enthusiast Joined Mar 30, '09 From dumfries, uk Currently Offline Reputation: 0 (0%) |
HOW TO GUIDE:-Fitting Guide
JSP - Solid Shifter Base Bush Kit - Celica GEN 6 -:Tools required:- ![]() JSP – Solid Shifter Bush Kit Flat Blade Screwdriver Philips Head Screwdriver 8mm Spanner 12mm socket (with ratchet and extension) ------------------------------------------------------------------------------- 1. Unscrew the gear knob ![]() ------------------------------------------------------------------------------- 2. Lift up and pop off the gear lever surround, pull up at the back and it will un-clip. ![]() ------------------------------------------------------------------------------- 3. Underneath the surround, unplug the cigar lighter plug. ![]() ------------------------------------------------------------------------------- 4. Remove the 2 x 12mm bolts located in the arm rest compartment between the front seats. ![]() ------------------------------------------------------------------------------- 5. Remove the 2 x screws behind the gear lever surround recess. ![]() ------------------------------------------------------------------------------- 6. Lift the centre arm rest section up and away (putting the hand brake on full will help). ------------------------------------------------------------------------------- 7. Unplug the ashtray light plug underneath ![]() ------------------------------------------------------------------------------- 8. Remove the 2 x 8mm bolts down by the seat edges. ![]() ------------------------------------------------------------------------------- 9. Remove the 1 x screw in the drivers footwell. ![]() ------------------------------------------------------------------------------- 10. Remove the 1 x screw in the passenger footwell. ![]() ------------------------------------------------------------------------------- 11. Remove the main dash front panel (see below) ![]() ------------------------------------------------------------------------------- 11(a). Remove the 2 x screws securing the bottom of the dash panel. ![]() ------------------------------------------------------------------------------- 11(b). Then pull the panel towards you at the top, the easiest way to do this is to adjust the vents like in the picture below, this allows you to get your finger tips in the top to give you something to pull. ![]() ------------------------------------------------------------------------------- 11©. Once free, you will need to look at the back of the panel and disconnect the wiring plugs attached to the clock and the hazard warning button, then remove the panel completely. ![]() ------------------------------------------------------------------------------- 12. Remove the 2 x screws at the top of the heater controls. ![]() ------------------------------------------------------------------------------- 13. Remove the plug on the back of the heater control unit and remove the heater control fully. ![]() ------------------------------------------------------------------------------- 14. Remove 2 x screws above where the heater controls were. ![]() ------------------------------------------------------------------------------- 15. Unclip the lower dial surround. ![]() ------------------------------------------------------------------------------- 16. Remove 1 x screw found behind surround. ![]() ------------------------------------------------------------------------------- 17. Unclip and pull down lower drivers footwell panel. ![]() ------------------------------------------------------------------------------- 18. Unclip drivers side clip by pulling panel towards you. ![]() ------------------------------------------------------------------------------- 19. Unclip Passenger side Clip by pulling panel towards you. ![]() ------------------------------------------------------------------------------- 20. Pull dash section free and remove completely ![]() ------------------------------------------------------------------------------- 21. Use flat blade screw driver to pry off cable clips and push wire looms to the sides. ![]() ------------------------------------------------------------------------------- 22. Remove 4 x 12mm bolts holding down the shifter assembly. The assembly will now be free. ![]() ------------------------------------------------------------------------------- 23. The old Rubber Bushes should look like this. ![]() ------------------------------------------------------------------------------- 24. Push/Slide the metal insert downwards, until it comes free from the bush. ![]() ------------------------------------------------------------------------------- 25. Remove rubber bush from the assembly. Do this for all 4 corners of the assembly. ![]() ------------------------------------------------------------------------------- 26. Old rubber bush and new JSP – Solid Bush ![]() ------------------------------------------------------------------------------- 27. Fitting the new solid bushes is easy. Simply push the new bushes into the assembly from the bottom, again do this on all 4 corners. ![]() ![]() ------------------------------------------------------------------------------- 28. Once all 4 bushes are in place, put the assembly back in place and refit the bolts tightening them evenly to ensure the shifter assembly refits correctly. ------------------------------------------------------------------------------- 29. Refit everything the same way you took it off (following the guide in reverse order). ------------------------------------------------------------------------------- 30. Take your car for a drive and see how she feels!!! ENJOY! |
Dec 7, 2009 - 11:11 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
Umm, are yall accepting orders from the states now. Last i checked about a week ago, i was turned down because one of your reps said you dont ship anywhere but england and ireland i believe. Anywho, would nice looking product, would be nice if it could be bought and shipped to my address with no issues. ^_^
-------------------- (\__/)
Dec 7, 2009 - 2:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
What exactly does this do?
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Dec 7, 2009 - 3:05 PM
Enthusiast ![]() ![]() Joined Nov 15, '08 From Merced, CA Currently Offline Reputation: 3 (100%) |
Dec 7, 2009 - 5:53 PM
What exactly does this do? Increases shifter precision. The stock rubber bushings have a little play in them and wear out over time. So it will shift faster then with stock rubber bushings? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Dec 7, 2009 - 6:18 PM
What exactly does this do? Increases shifter precision. The stock rubber bushings have a little play in them and wear out over time. So it will shift faster then with stock rubber bushings? Not faster. It will just have a better feel |
Dec 7, 2009 - 9:13 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '06 From Northampton, UK Currently Offline Reputation: 5 (100%) |
Not faster. It will just have a better feel Yup, changing feels more positive and much less shifter wiggle when in gear. -------------------- Davey
Items for sale |
Dec 7, 2009 - 10:38 PM
Not faster. It will just have a better feel Yup, changing feels more positive and much less shifter wiggle when in gear. Ahh I see, sorry just trying to learn as much as i can. Is this a common mod? I mean, I know a bit about cars, and i know a lot of common mods guys do, but I've never heard of this before. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Dec 8, 2009 - 12:58 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
wow I didnt have to do steps 10 - 20 when I put my quickshift in, but great write up.
| Lo-Fi Version | Time is now: April 13th, 2026 - 1:54 AM |
