Dec 16, 2009 - 7:44 PM
Enthusiast ![]() ![]() Joined Jun 25, '08 From CA Currently Offline Reputation: 0 (0%) |
So when i start my car it idles very rough and even if you pick up the rpms to 2000 or 3000 you can still feel its running noticeably rough it'll last if you keep the rpms above 1500 but when it goes to idle it'll die in a few moments and then it wont start for a while.could this be the alternator going bad? I've checked all fuses and they seem fine, and also the check engine light came on so any ideas on whats wrong with it?
Dec 16, 2009 - 8:38 PM
check the IAC (may need to clean it) and check that the vac line to the MAP sensor is connected. any mods or recent changes to the car?
if you keep the idle speed up manually (foot on pedal) will it run ok after about a minute? -------------------- |
Dec 16, 2009 - 8:53 PM
check the IAC (may need to clean it) and check that the vac line to the MAP sensor is connected. any mods or recent changes to the car? if you keep the idle speed up manually (foot on pedal) will it run ok after about a minute? Well I changed the oil this morning but it ran fine after i changed it, well my i took the car around the block keeping the rpms a little high and it ran terrible, it felt like i had no power. but after i got home i popped the hood and noticed smoke coming from the distributor area and not long after that it seemed to idle fine so i left it on for a few minutes and took it around the block and it seems completely fine now except the check engine lights on still. But on another note when I checked the Oil the Holder for the Dip Stick came out and its still noticeably loose and the dip stick doesnt seem to pick up any oil either? |
Dec 16, 2009 - 9:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
whoa no OIL!? check your levels!? did you put the drain plug back in tight!? also check the engine code via paperclip method
-------------------- Breaking Axles...
Dec 17, 2009 - 12:37 AM
yeah theres no oil comming out of the drain plug and I put over 4 quarts so im sure theres oil. and if i put the dip stick in the hole without that holder device in it'll pick up oil but that holder won't stay in place it swivels and if i pull the dip stick to hard it brings the holder out too. but also I have a new thing the car seems to run fine now but the check engine light is still on and If you smell my exhaust it smells like sulfur or a rotten egg.
| Lo-Fi Version | Time is now: August 26th, 2026 - 4:41 AM |
