Dec 20, 2009 - 12:28 PM
Enthusiast ![]() Joined Apr 6, '09 From Mass Currently Offline Reputation: 0 (0%) |
so after installing my new engine on my 94 celica gt, i am now idling at around 2 grand cold start and between 1200-1500 at warm idle. Ive checked my timing, vaccume lines, and throttle positioning sensor. Nothing seems to change it. What else could this be?
Dec 20, 2009 - 5:11 PM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
so after installing my new engine on my 94 celica gt, i am now idling at around 2 grand cold start and between 1200-1500 at warm idle. Ive checked my timing, vaccume lines, and throttle positioning sensor. Nothing seems to change it. What else could this be? You have alot to look at... Air / Fuel / Electrical check the FPR (fuel pressure regulator) if ur geting too much fuel, ull run rich with a high idle.. you may have a fresh gasy smell from the exhaust. check the EGR valve, if its stuck open you will be stucking in extra air, e.i higher idle. if the EGR is faulty it will emit a rather nasty smell lol. go to a local shop and check for codes, injector cycle could be out... o2 sensor(s) may be fried.... |
| Lo-Fi Version | Time is now: July 10th, 2026 - 9:35 AM |
