Dec 22, 2009 - 2:50 PM
Enthusiast ![]() Joined Nov 27, '09 From New Zealand Currently Offline Reputation: 1 (100%) |
Hi guys.
OK, I've taken delivery of my new TRD quickshifter, so need to install it. I'd like to do it myself but I'm basically a rank noob at DIY So I guess a good starting question is what tools might I need If anyone can provide a bit of a walkthrough (or point me to one) that would be appreciated Cheers! b |
Dec 22, 2009 - 2:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
You didn't search. If you were to look in the How-To secion of the site you would see there was a walkthrough posted years ago. Pictures and all.
Edit: Did the work for you. http://www.6gc.net/howto/install_trd_quickshifter This post has been edited by 95CelicaST: Dec 22, 2009 - 2:53 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Dec 22, 2009 - 3:23 PM
Thanks, that looks pretty comprehensive
Dec 22, 2009 - 6:27 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Rusty just did his recently and posted about it.
I'm envious of you guys quickshifters -------------------- Mike W
Dec 22, 2009 - 11:15 PM
Enthusiast ![]() Joined Oct 26, '09 From Florida Currently Offline Reputation: 2 (100%) |
nice! does anybody know where i can get a TRD quickshifter? nobody seems to have it? does the 7gen one work?
Dec 22, 2009 - 11:31 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 10, '08 From sweet home, OR Currently Offline Reputation: 3 (100%) |
7gen works
Dec 23, 2009 - 12:22 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Rusty just did his recently and posted about it. I'm envious of you guys quickshifters Its all on how u shift and drive like I tell people manual transmissions is not for everybody. "Anyone who says that a short shifter has caused excess wear on their gearbox needs to learn how to shift gears properly." -Quoted from the link Busting the "shortshifters cause excess synchro wear" myth <<Clicky -------------------- "To Protect And To Serve The Wealthy" -POLICE
Dec 23, 2009 - 12:47 AM
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
lol I'd imagine it would wear the syncros as much as any normal fast shift.
Dec 23, 2009 - 4:51 AM
Enthusiast ![]() ![]() ![]() Joined Nov 4, '09 From Sacramento, California Currently Offline Reputation: 0 (0%) |
say Quidam, can we see some pictures of your beauty with a small upgrade after you install?
-------------------- Brand new 6gc owner! (sort of 2011)
The world is moving around a sun, the sun moves around a local arm of the galaxy, the local arm of the galaxy moves around a gigantic black hole. |
Dec 24, 2009 - 12:23 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
I can help you if you want?
Dec 24, 2009 - 5:46 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
TRD Quick shift remains my favorite mod to date, worth it every time you drive.
Really easy to install too. -------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Dec 27, 2009 - 3:36 AM
Rusty just did his recently and posted about it. I'm envious of you guys quickshifters Its all on how u shift and drive like I tell people manual transmissions is not for everybody. "Anyone who says that a short shifter has caused excess wear on their gearbox needs to learn how to shift gears properly." -Quoted from the link Busting the "shortshifters cause excess synchro wear" myth <<Clicky Haha okay, The thing is when you select the gear (Especially in our cars) you bring the shifter up to the position of the gear and gently guide it in, you still have to wait a split sec for the syncro to spin up the gear before it accepts it happily, otherwise it crunches, This is regular street driving. If you can crunch a gearbox regular shifter, then how is a shorter throw going to allow you to shift quicker without crunching the gearbox? When you're on the track, you're going to want to shift as fast as possible which means either way waiting for the syncro or forcing it in, short shift or not? Does this mean it's only for aesthetics and not entirely functional? -------------------- Mike W
Dec 27, 2009 - 4:21 AM
Fitted
Just got back from a test-drive and everything seems a-ok. I don't think it will take long for me to get used to it, and for sure, you find the gears a lot faster with this stick, there is simply less physical movement involved. I had one weird moment where I thought I was in 1st but was in 3rd, and I think it's just because the movements are so small now it is perhaps a bit easier to misjudge. So this was my first mod, and I'm glad I did it myself! In fact in hindsight I'd say this is the sort of job where you are likely to do a better job of it than some mechanic who really doesn't care about your car. Didn't go entirely smoothly, first headache was when I was disconnecting the left side cable off the original shifter assembly and the little metal clip that keeps it in place sprung off the stud and disappeared into thin air. After swearing loudly my gut instinct told me it had lodged itself under the passengers side carpet, because that is exactly where I would put it if I were Murphy's Law. So I took the passengers seat out (pleasantly surprised to find how easy that was) and was kind of shocked at all the dust and crap under it. I therefore figured the drivers side was likely to be even worse so took that seat out as well. Anyway, my assumption about Murphy was spot on, and the clip was exactly where I thought it would be -relieved to find it! Cleaned up the mess with my mini-vac. I also got very annoyed with the metal horse-shoes that hold the cables in place on the shifter assembly. I used pliers, but it was kind of awkward getting the right angle to apply leverage. I could feel myself getting red in the face with frustration as I battled with them. Finally I got my technique sorted out and off they came. Interestingly, I didn't find what was supposed to be the hardest part very difficult. The center cable that fits to the bottom of the gear lever via a ball and socket connection came off pretty quickly. I'll admit getting it back on took a bit longer, but was still not too bad. Apart from the metal horse shoes (which I hope I never have to deal with again) I did find getting the original shifter assembly out of the chassis a pain in the butt as well (Strangely getting the new assembly in was a lot easier, but I still had to play twister with it) I simply did not want to cut the plastic. So instead I removed the heater/air con unit and face plate. With the seats out as well, I was able to get in very good position to wiggle the unit out, but it took a bit of twisting and turning! My advise to anyone else doing this, would be to take the seats out. I kind of wish I'd done that right from the start. You have more room to work and you may as well give the interior a bit of clean while you doing a job like this anyway. ps. While doing this work I found a Japanese coin under one of the seats lol. Been there a long time no doubt. pps. what are the cables for under the seats that connect ot the seat itself?!? On the passengers side it looked like the cable had been cut off. The drivers side cable was still complete.. OK, stand by and I'll post some pics This post has been edited by Quidam: Dec 27, 2009 - 4:33 AM |
Dec 27, 2009 - 4:26 AM
Dec 27, 2009 - 4:51 AM
bits I had to remove:
![]() Finally got the old shifter unit out, ready for the new one to go in: ![]() No seats! ![]() Stripped cable I found under the passengers seat: ![]() Same cable intact on drivers side (was awkward to disconnect from seat): ![]() Pivotal moment, as I managed to connect the ball-and socket of the shifter and cable together ![]() New unit in and screwed back down (with supplied spacers installed under the assembly, as advised per tutorial) You can also see the s.o.b. metal horseshoes near the top of the picture that hold the cables onto the plastic Assembly ![]() putting it all back together: ![]() ![]() Finished product! ![]() ![]() This post has been edited by Quidam: Dec 27, 2009 - 4:55 AM |
Dec 27, 2009 - 12:01 PM
Looks great!
I've done 4 or 5 shifter installs on 6th gens, so the entire ordeal takes me 15 minutes or so, but its always nice to go back and see others do it. For example, the horseshoe clips you grab and wiggle side to side and they pop off. And all you really need to remove is the center console and the shifter trim. Just be ready to get your hands cut up from the plastics. Excellent first mod. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Dec 27, 2009 - 12:12 PM
hawkesbay. (was going to walk you through it) wow you did alot of work to install it, but congrates on the install.
Dec 27, 2009 - 12:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
OMG, do you not see what you messed up? You accidentally reversed the dash!
In seriousness, nice. I would go with a short shifter as well if I had a manual...I still could in the future. -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Dec 27, 2009 - 2:00 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
ya i put the 7th gen short throw and i LOVE IT!!! u dont have to disconnect any cables either, it wasnt hard at all, just have to be careful anddont brake any parts but its not overly breakable.. took me like 45 min
-------------------- st205 powered ss3 coupe
Dec 27, 2009 - 3:29 PM
This community is great, I would not have tried to do this by myself if I had not had your guys advise and support. ps. in hindsight I agree it was not that hard, but I also think there is a real chance of breaking something if you are reckless, you do have to be a bit careful. Also, the first time you do anything it always takes a lot longer and I took my time on purpose because I didn't want to f!ck anything up This post has been edited by Quidam: Dec 27, 2009 - 3:32 PM |
| Lo-Fi Version | Time is now: June 24th, 2026 - 2:08 PM |
