Dec 28, 2009 - 7:42 PM
Enthusiast ![]() Joined Apr 13, '09 From MA Currently Offline Reputation: 0 (0%) |
The low beam headlamp seals seem move pretty easily in my 98 GT. I saw that a clip was holding the seal to the assembly in one spot and figured the last guy who had it apart forgot the other clips. But I took the head lamps out today to see and the other spots where the clips are, there is no lip on the rubber seal to grab. Any ideas of what may have happened or how to have it so they fit snug? Thanks
Dec 28, 2009 - 8:22 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 5, '05 From pineapple under the sea Currently Offline Reputation: 9 (100%) |
Are you talking about the metal clips that hold the rubber ring to the headlight? There are I think two on each lamp, and chances are you need to replace the clips and the rubber rings if you can't find where the tab mounts.
Dec 28, 2009 - 8:32 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) |
Mine have the same problem they are sort of lose they just dont hold well
Dec 29, 2009 - 10:20 AM
![]() Enthusiast ![]() ![]() ![]() Joined Sep 29, '09 From Prince George, BC CANADA EH! Currently Offline Reputation: 8 (100%) |
I just attached my seals to the housings using silicone, they've been good so far
-------------------- ST205 Crew represent
![]() Challenge Accepted |
Dec 29, 2009 - 10:38 AM
@95CelicaST Yes I am, there are like 4 clips present, but only one is able to grab on the rubber, where the other clips are there is a indent in the rubber and no lip for the clip to hold so it is merely holding the glass to the plastic assembly.
| Lo-Fi Version | Time is now: June 24th, 2026 - 4:46 PM |
